Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-13-2011, 10:07 PM   #1
EEG
Kitchen Counter Top
Hi Everyone
Forgive my silly question, but when cutting a Formica kitchen countertop with backsplash, do you cut it with the laminate side up?
thanks
EEG is offline   Reply With Quote
Old 12-13-2011, 10:42 PM   #2
Kitchen Counter Top
if you are using a circular saw you cut with the good side down.
Old 12-14-2011, 12:29 AM   #3
EEG
Kitchen Counter Top
Thank you so much.. Yes I am using a circular saw ..
Thanks again for the quick respond
Old 12-14-2011, 03:24 AM   #4
sdsester's Avatar
Kitchen Counter Top
Still not a bad idea to put some masking tape on the laminate side just in case you happen to hit a section that tries to delaminate. And use the correct saw blade.
sdsester is offline   Reply With Quote
Kitchen counter top oscar62 Remodeling 2 06-25-2011 07:19 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 08:59 AM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
Granite tile as a kitchen counter? fun4me Building & Construction 1 04-13-2009 05:55 PM
Is there any typical height for Kitchen Counter outlets NHERal Electrical 9 03-23-2009 07:28 PM
