Kitchen Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-04-2010, 10:05 AM   #1
Kitchen cabinets
I'm remodeling my kitchen but don't have enough cabinets. I'm building cabinets but wondering if I can use pine instead of a hardwood for the face plates. The finish is no problem since the cabinets will be painted.
buenof is offline   Reply With Quote
Old 04-04-2010, 12:17 PM   #2
jlhaslip's Avatar
Rewards Points: 994
face plates???
do you mean the doors and drawer fronts?
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 04-04-2010, 12:34 PM   #3
Carpenter/Rehabber
moorewarner's Avatar
I say yes, maybe a cabinet guy will blow through and offer some pro & con info.
moorewarner is offline   Reply With Quote
Old 04-04-2010, 05:11 PM   #4
Kitchen cabinets
Yes, I mean doors and cabinet fronts. Can or should I make them using pine instead of hardwood
Old 04-04-2010, 05:36 PM   #5
DIY staff
Rewards Points: 7,174
Pine would not be a first choice--to soft and a lot of movement with humidity changes.
Poplar is inexpensive and is easy to work--takes paint well--stable too.
See if you have a hardwood store close by--better selection and price usually.
I buy from small saw mills-if you are in an area with wood cutters--that is a good option ,--Mike---
Old 04-04-2010, 05:42 PM   #6
Kitchen cabinets --- pine
Thanks for your input, Mike
There is a Habitat ReStore in the area. They sell several varieties of reclaimed wood from demolition projects.
The Following User Says Thank You to buenof For This Useful Post:
oh'mike (04-04-2010)
Old 04-06-2010, 01:41 PM   #7
You must mean the face frames. Even cheap cabinets have them made from hardwood. Low grade hardwood, but still hardwood. You could also try MDF which pretty common. I woudl still stick with poplar if you are going to paint it. You can usually get S4S poplar at most lumber yards or big box stores. It would niot be much more than S4S pine and would be a better choice.
beerdog is offline   Reply With Quote
Old 04-06-2010, 04:43 PM   #8
Kitchen cabinets, pine or?
Thanks, Beerdog
I will take your suggestion and go with poplar. I don't have much experience with cabinet making so I'm experimenting with my tools and using whatever materials I have on hand --- mostly pine. If I can demonstrate any competence I'll proceed to the better materials.
Old 04-06-2010, 05:03 PM   #9
Practicing with pine or even plywood is not a bad idea.
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 07:14 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 11:23 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
