Kitchen Cabinet HELP! - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 10:13 AM   #1
castroball5
Kitchen cabinet HELP!
Quick question. I'm building a base cabinet for my kitchen. I'm going to do a slate tile countertop. My question is how much overhang (if any) should I cut my plywood substrate and concrete backer board?
castroball5 is offline   Reply With Quote
Old 06-26-2013, 10:33 AM   #2
Old School
Willie T's Avatar
Cut so that the finished surface is 1 1/4" is about right.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
oh'mike (06-26-2013)
Old 06-26-2013, 01:55 PM   #3
Rewards Points: 1,470
Depends on what you're going to finish the edge with.
I see the overhang typically coming out roughly 1/2" beyond the drawer/door fronts.
ktkelly is offline   Reply With Quote
Old 06-26-2013, 02:26 PM   #4
castroball5
Ok thanks. I'm going to use a bull nose tile for the edge. The front is the only part that should overhang right
Old 06-26-2013, 03:06 PM   #5
Old School
Willie T's Avatar
The sides next to a range or refrigerator should not overhang any more than the tile thickness, but if it is an open end, then the side overhang should match the front. (Some people like them 1/4" to 1/2" shorter because there are no drawers or doors on the sides.) Your choice, of course, but keep in mind the possibility of maybe having to match a pattern on top.
Willie T
Old 06-26-2013, 03:30 PM   #6
castroball5
Cool thanks all
Access through kitchen cabinet to pipes taylorroad Carpentry 4 09-01-2012 06:09 AM
Kitchen cabinet conundrum allbymyself Kitchen & Bath Remodeling 18 01-24-2011 11:11 PM
outlet in kitchen cabinet timchi29 Electrical 2 01-03-2011 08:25 PM
kitchen cabinet mircrowave range marin001 Building & Construction 1 12-10-2010 05:32 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
