Kitchen Cabinet Broken - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 08:20 PM   #1
Weekend Builder
Crackers's Avatar
Hello,
I have a 6 year old kitchen made of thermoplastic. This year one of the doors broke off ( ) for no apparent reason. What can I do to reattach the hinge to the door so that I can put it back up. Part of the problem is the size of the door, so it is under a lot of pressure.
Here is a picture of the opening, you can see it is a hinged (articulating I think it is called) door, not just a simple hinge.
Here is also a picture of where the hinge attachment was.. 2 shots..
Kitchen Cabinet Broken-kitchen-door-opening.jpg   Kitchen Cabinet Broken-january-march-08-193.jpg   Kitchen Cabinet Broken-january-march-08-194.jpg
Crackers is offline   Reply With Quote
Old 03-24-2008, 08:43 PM   #2
Custom Cabinet Maker
Since the material is MCP panel, or TFM, only thing I can think of is to carefully drill those holes oversized and glue dowels into them, once set re drill for the screws. More than likely they are 5mm Euro screws.
Use a forstner bit to drill the holes BE SUPER CAREFUL so u dont breakthru the face.
skymaster is offline   Reply With Quote
Old 03-24-2008, 10:12 PM   #3
BuilderRemodeler
Dowells sound like the a good choice.
Redneck method may work also and might be worth trying... I'm not recommending this but have seen it work on regular house door hinges and last for many many years.
Be very very carefull - Place masking tape to keep your cabinets clean around area prior.
Then use Premium subfloor adhesive in the area where the screws came loose and attach the cabinet portion of the hinges exactly where they need to be. After it is completely dry re-attach your door.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Old 03-24-2008, 10:23 PM   #4
Finish Carpentry Pro
You could try something like this out. http://www.dri-sil.co.uk/driplate.html
Quiglag is offline   Reply With Quote
Old 03-27-2008, 09:40 PM   #5
remodeling pro
. Ouch.... I'd stick with skymasters method over this for sure. Definatley a forstner bit, preferrably in a drill press, but can be done carefully by hand. Rather than fighting to trim a dowel flush without damaging the door skin, I have glued in flat headed plug. It generally takes a 3/8" sometimes 1/2" diameter to get beyond the damaged area.
troubleseeker is offline   Reply With Quote
Replacing Kitchen Cabinet Door Hinges Eric_ht Carpentry 4 04-18-2008 07:42 AM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 01:05 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
Help! Our contractor made our kitchen cabinet door stain TOO ORANGE! Nikki99 Painting 12 11-19-2007 11:45 PM
average cost for kitchen cabinet refinish sil Painting 4 11-05-2007 10:24 PM
