Kitchen Cabinet Braket Loose - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 02:49 PM   #1
Rewards Points: 878
Kitchen Cabinet braket loose
The top and bottom screw just keep turning and does not get tight. I think the hole is too big or no good anymore(what is the trade term for that?? the screw is not stripped is the hole stripped). I took the screw out and was thinking of putting a bigger screw as that in turn would make a bigger hole and it would catch. But the extg. screw just fits in the hole of the bracket so I can't put a bigger one. I also can't move the bracket and screw new holes because that in turn will make the cabinet not line up. Any suggestion? I would like to go to HD now to try and fix this. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 02-23-2013, 03:29 PM   #2
Rewards Points: 42
Glue a golf tee or wooden dowel into the two holes. When dry, drill pilot holes for the screws.
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Mstrlucky74 (02-23-2013)
Old 02-23-2013, 04:58 PM   #3
Rewards Points: 878
Well I adjust the bracket so the hole move slightly to the right of the extg. holes. I drill a small hole and then starting screwing the screws but I guess they were too close because the wood(looks like particle board) just mushed in. DAMN. I should have listened to the the suggestion to put dowels in the holes. My wife get home from work in an hour...uh oh
Old 02-23-2013, 06:07 PM   #4
Rewards Points: 42
You can still repair it with dowels. Use multiple holes. Let the glue cure overnight before trying to drill the new holes.
Old 02-23-2013, 06:52 PM   #5
Rewards Points: 878
Thanks..at least I had nice pork chop recipe , potatoes and brussel sprouts waiting for her!!!! Yeah man!!
Floating Kitchen Cabinet install zaphod42 Carpentry 4 02-12-2013 07:27 PM
Access through kitchen cabinet to pipes taylorroad Carpentry 4 09-01-2012 06:09 AM
kitchen cabinet mircrowave range marin001 Building & Construction 1 12-10-2010 05:32 PM
Kitchen cabinet question MagicalHome Remodeling 2 11-21-2010 07:31 AM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 09:16 PM
