Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-29-2007, 08:17 PM   #1
Kitchen Cab trim
I am installing crown and triple bead molding on the top of my kitchen cabinets. When the run of the molding is longer then the actual piece. what is the best way to cut it to seam them together. Thanks
tonyD
TonyD is offline   Reply With Quote
Old 04-29-2007, 08:53 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Kitchen Cab trim
tonyD
Hi,
We like to use the 33.9° Bevel detent....(Preset detent on the compound miter saw) and match the next piece to it.
Your best bet is to try and get the 'break' or seam over a stud.
Set the length (that is attached to the wall 1st) with the 'cut-side' facing up. Attach the 2nd length with the 'cut-side' facing down and onto the 1st length....
We like to attach these together using wood glue and 18g brad nails to hold them together at the seam.
Then attach the pieces into the stud behind: Nail thru the seam so that the 15g to 16g nail passes thru both lengths of stock and into the stud. Normally, if you just went ahead and did this without glueing and attaching the seam first, the two ends could shift when the nail gun is fired and become slightly mis-aligned...
I'm sure that there may be other tips from other members....
- Build Well -
Old 04-29-2007, 09:01 PM   #3
remodeling pro
Kitchen Cab trim
The "old standard" is to cut the joint on both a 45 degree bevel and miter, but I personally never liked the long diagonal seem this gives. I prefer to just cut a 45 degree bevel straight across the pieces and glue them up. If the cabinets are open above, I glue a backer block across the seam, held in place with a couple of spring clamps until the glue dries. Try to put the seam in as inconspicious location as you can, and cut so that you are looking acros the top on the seam from the most common viewing area. I often us the factory preset crown bevel also, just to eliminate the chance of the saw not being reset before the next crown cut.
Last edited by troubleseeker; 04-29-2007 at 09:45 PM. Reason: add factory crown preset comment
troubleseeker is offline   Reply With Quote
Old 04-30-2007, 09:29 AM   #4
Kitchen Cab trim
Thanks for clarifying that Troubleseeker.
Obviously, my answer was based on crown-molding installed on a wall.....
- Build Well -
Old 04-30-2007, 01:16 PM   #5
Kitchen Cab trim
Thanks AtlanticWBConst & troubleseeker for the advice.
TonyD
More On This Topic
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today we are here to talk about cordless nail guns. Let's take a moment and talk about nails. This particular manufacturer of cordless nail guns requires that you use... Read More »
Hi I'm David Belch with Thermo Guard and today on behalf of Expert Village I am here to show you how to install windows. What I want to show you now is how to measure a wood sash window. The wooden windows come with a wooden jamb frame header and sloping... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be talking about tips for buying a stud finder. I have two different types of stud finder tools and each one has its own pros and cons. On our first tool our stud finder gives us the... Read More »
Using a Nail Clipper
Using a Nail Clipper by Expert Village
Hi, my name is Theresa, and I'm here to demonstrate and show you how to use a nail clipper. Here we have a nail clipper, right here, and here we have a toenail clipper. This is for your feet and this is for your hands. Some of the nail clippers do have a... Read More »
So we’re working on our outside corner piece here. We’ve got our first piece done. It fits in just like that and you can see now why it is important to measure it from the back of your piece. We would have measured from the front of our piece... Read More »
Sidelight - Cannot find vinyl trim lrichards Building & Construction 2 08-28-2008 05:42 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
