Kiln Dried Syp - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 03:00 PM   #1
Carpenter
kiln dried syp
what does the HT stand for in KDHT?
marttinen is offline   Reply With Quote
Old 03-24-2011, 03:56 PM   #2
just a tool guy
mickey cassiba's Avatar
In my understanding, it stands for "Heat Treated" a form of Kiln Drying that is supposed to destroy pests, their eggs and larvae...could be wrong though, It's happened once or twice.
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 03-24-2011, 06:55 PM   #3
Mickey's correct it's heat treated.
Heat treated lumber may be marked as KD-HT or HT. If marked KD-HT, the lumber is being guaranteed as 19% or less moisture content and that it has been heat treated to at least 56 degrees C (minimum of 133 degrees F) for at least 30 minutes at the lumber core. A mark of HT signifies that the lumber has been heat treated to at least 56 degrees C for at least 30 minutes at the lumber core, without moisture content designation.
Gizmoman is offline   Reply With Quote
Old 03-24-2011, 09:27 PM   #4
Registered User
Rewards Points: 5,466
Welcome to the forum, marttinen! Please stop asking the same question in numerous threads. Thank you.
Gary
How can I remove dried epoxy resin from hardwood flooring? Kay Manuel Painting 1 03-22-2010 08:41 PM
want to make an ultra cheap wood kiln - any advice? wombosi Carpentry 5 03-20-2010 04:39 PM
How to get rid of dried paint? StevenH Painting 4 11-11-2009 04:52 AM
240V Kiln Outlet to Air Conditioner Outlet artman Electrical 8 06-29-2008 06:21 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
