Kids Loft Bed - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 10:33 PM   #1
Kids loft bed
Hello,
this is my first post so please excuse my rookie-ness!
I'm planning on making a loft bed that will span the size of the room... 12'. My question is, can I cover this span with no posts contacting the floor? I would love to just lag bolt ledger boards to the walls and use 2x6 as "floor" joists in joist hangers. the loft will be supporting two twin mattresses and two active toddlers.
thanks
baron770 is offline   Reply With Quote
Old 01-19-2012, 12:42 AM   #2
Rewards Points: 2,212
If you could get douglas fir and put them on 12" centers you would be close 11'-4" clear span.http://www.awc.org/calculators/span/...al+Span#answer
mae-ling is offline   Reply With Quote
Old 01-19-2012, 01:11 AM   #3
Retired carpenter
Two toddlers. . . two matresses. . . stuffed animals. . . 200 pounds max? That's nothing for 2x6s.
abracaboom is offline   Reply With Quote
Old 01-19-2012, 06:39 PM   #4
Thanks a lot!
love the span calculator....
what's the difference between live load and dead load?
Old 01-20-2012, 03:18 AM   #5
Retired carpenter
Dead load will be the weight of your loft frame.
Live load will be the weight of matresses, children, etc.
That calculator is designed for much greater live loads (furniture, big people, etc.).
Old 01-31-2012, 03:52 PM   #6
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
I Did one similar last year for my youngest's bedroom, pre-made a solid 2x8 frame, pre drilled everything and bolted it togather on floor, Mine was mounted in corner ,so a head end and a long end were attached to the wall at every stud with lag's, leaving only one corner out in the field, Made a post and tied it into the steps and i haven't had any issue's so far, knock on wood,Sanded,prepp'ed,painted colors that he picked out. But with that span, using the right material, I think it would be fine,+1 on Doug fir ,only thing you cant account for is the rambucious spirit of kids, good luck
jpc is offline   Reply With Quote
Old 01-31-2012, 04:05 PM   #7
Meep!
Joe Dirt's Avatar
That's no larger than most loft beds in dorm rooms- we had some boards going from the post to the cross member for support, but there was a LOT more weight up there than what you would have. Just my experience... We used 2x6's for the cross members and 4x4's for the posts. Not sure if it was entirely correct, but it lasted 3 years until we sold it to new residents when we moved off campus.
Joe Dirt is offline   Reply With Quote
Old 06-11-2012, 08:23 AM   #8
What!?
Evstarr is offline   Reply With Quote
Old 06-11-2012, 09:00 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
^ indeed, a thread is re born!
hand drive is offline   Reply With Quote
Old 06-12-2012, 10:10 AM   #10
Reborn or raised from the dead zombie style?
Redecoration without painting in kids' bedrooms feselleL Remodeling 1 02-15-2011 04:12 PM
Twin Size Loft Bed construction.. for a dummy what_silliness Building & Construction 2 01-15-2011 02:53 PM
Hanging loft from glulam beam, pics inside. wackerjr Building & Construction 20 01-05-2011 08:55 PM
Need Veg Garden ideas for kids at a hospital Leah Frances Gardening Forum 2 04-21-2010 11:39 AM
How would i finish this loft???? (pics) oregonrebel Building & Construction 3 03-31-2007 08:01 AM
