Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-28-2009, 11:41 AM   #1
Keeping Door Propped Open
My wife always likes to keep the door to the garage propped open a foot or so. Several reasons really, give the cat access, keep the garage a bit cooler and more ventilated, etc. She currently accomplishes this in pretty crude fashion- wedges a folding chair in between the door and the wall or the door and the frame. As I just painted the door and wall, I need to find a better way. The door is a good 6" above the garage floor, so a simple door stop won't work.
My first attempt was a chain bolted to the back of the door and to the wall in the garage. Works ok, but the chain makes a lot of noise when the door is open and knocks stuff over.
Then I thought about the pneumatic door closers commonly used on commercial doors. Look nice, a bit pricey, but I can't seem to find one that will lock in a particular position. Then, there are the storm/screen/patio door closers. Most (at least what I've seen at Home Depot/Lowes) seem very flimsy and I doubt will last very long with a solid-core wooden door.
What other options are there? Should be easy to use, pretty unobtrusive, and be able to keep the door open both a small distance from closing and open all the way (for bringing groceries in and out and such).
dgreco3917 is offline   Reply With Quote
Old 09-28-2009, 12:46 PM   #2
How about a small C clamp on the track under the bottom roller?
47_47 is offline   Reply With Quote
Old 09-28-2009, 01:14 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Your track doesn't have holes in the sides?
Usually there are holes & the lock system can be used to keep the door open
I've also seen people do this with a drill & pin
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Scuba_Dave is online now   Reply With Quote
Old 09-28-2009, 01:23 PM   #4
Sorry, it is not the rollup garage door, it is the door from the garage to the kitchen. Just a standard interior (but solid-core) door.
Old 09-28-2009, 01:25 PM   #5
I think he is talking about man door in the garage not a garage door.
RegeSullivan is online now   Reply With Quote
Old 09-29-2009, 10:44 AM   #6
Oops,
You could make a simple wedge. You say you have ~ 6" between the bottom of the door and the floor. Take about a 12" long 2x6 and to one 1½" edge screw a 2x2 perpendicular to it at one end. You can also screw in another vertical piece as a handle.
You could also make a more defined wedge using power tools.
Old 09-29-2009, 10:19 PM   #7
morningwood
Hmm,
open window, put in small pet/cat door in the man door?
rahfiki is offline   Reply With Quote
More On This Topic
Hello! This is Ross on behalf of expertvillage.com. That is my kitchen door and it is dark outside, it really doesn’t matter I cannot see the garage door anyhow if it was light out because it is blocked by the wall here. I did have to get up to... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
Caring for your garage door can help you save money in the long run. By periodically doing some simple maintenance work, you can avoid serious problems with your garage door and having to spend large sums of money to replace or fix the problem. Here are... Read More »
Feng Shui Mirror Tips
Feng Shui Mirror Tips by Expert Village
So one thing that is commonly used in feng shui for cures, and also in the home office, are mirrors. In this particular room, I have two reasons to suggest mirrors. Well, one to suggest for this room and one to suggest in general. This room is sort of an... Read More »
Hello! This is Ross on behalf of expertvillage.com. Would you look at that… someone left the garage door open. Honey! You know, this electronic stuff is pretty easy. Can you get someone to close the garage door please… Read More »
Open Stairs in Basement ngerhard Building & Construction 4 07-10-2009 07:30 PM
Which should open first GFCI or breaker jamiedolan Electrical 14 01-19-2009 04:03 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
garage door open light deck hand Electrical 3 01-22-2008 09:29 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
