Just How Hard Would This Be ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-24-2014, 10:36 AM   #1
Rewards Points: 220
just how hard would this be ?
i want a small'ish roof over my back door. say 6'x7'ish. i really like this one =
http://beyonddecks.com/wp-content/ga...s/129_2924.jpg
but i am nervous about it, i think i am, once again, over thinking this.
and/or i am turning into a scaredy cat. and my "minds eye" isn't working as well as it used to.
2 8" peers 3'+ deep. 4x4 treated posts and framing. bolted to the house.
Fix'n it is online now   Reply With Quote
Old 08-24-2014, 10:53 AM   #2
Rewards Points: 1,218
That is fairly simple to add to any existing structure.
It is basically a post pergola, just attached to the home by a ledger instead of a post supporting the attached side.
And 4x4 treated posts will suffice for a small one.
ED
de-nagorg is offline   Reply With Quote
Old 08-24-2014, 11:08 AM   #3
Rewards Points: 220
just measured. 7' out and 6' wide.
Old 08-24-2014, 11:24 AM   #4
Rewards Points: 220
does this sound crazy ? all treated wood (except for top layer roof sheathing). using deck boards as the underside of the roof with plywood over top of that ? roofing felt in between ?
2x4" rafters ok or not ?
Old 08-24-2014, 12:09 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
The only thing that needs to be treated is the wood that touches concrete.
Prime and paint everything else and you will be fine.
I did something similar on a smaller scale for my front door.
This is what the roof over my front door used to look like. If it was raining, you got wet.
Then I built this. Roof line was complicated and I most likely over built the transitions to make sure it never leaks....but better safe than rooting.
Interesting thing....while I was building it, I had about 5-10 local residents stop and ask if I as a contractor. Over the next couple of years, we saw about 10 houses in the neighborhood do something similar. It really changes the look of the house.
Wow....looking back at those old pics made me go outside just now and take a pic....how the house has changed. And that is Noir our dog....doing as told and 'staying'.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
Gymschu (08-24-2014), hand drive (08-29-2014)
Old 08-24-2014, 02:06 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Looks good Dawg.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-24-2014, 02:15 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Fix, if you just look at each step you need to take building that, it won't be so bad. Back when I would get a huge house to build, it would overwhelm me until I looked at each step, kinda like putting a puzzle together, then it didn't seem so bad at all.
Jim
Old 08-24-2014, 02:45 PM   #8
PoleCat's Avatar
Rewards Points: 1,646
Good advice. This has always been my problem. I engage in trying to think the whole project through and end up confused and frightened.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-24-2014, 10:17 PM   #9
Rewards Points: 220
yes, i know, the one in my link looks great. but i am thinking that treated will match my deck, that would be right next to it. . a wise or dumb thought, idk.
you house looks great. if i may ask = how much did that raise your property taxs ?
Old 08-24-2014, 10:27 PM   #10
Rewards Points: 220
yeah, i know. when done, i will be hopefully kicking myself for being a sissy over it.
but at the same time, i am worried i would do something wrong and cause myself a bunch of greef. and i am wondering what type of roof or even if i should.
my minds eye needs glass's, doesn't work as well as it used to. and this is just some pimpy little roof.
damn, i have issues
Old 08-24-2014, 11:19 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
I would go with the same kind of roof you have on your home. Unless treated lumber has changed or they have come up with a new type of paint, I would think twice before using all treated lumber, paint don't stick well to treated lumber, also treated lumber twists, bows and cracks easily, not to mention harder to work with. JMHO
2X4s for rafters will be fine no wider than it will be. I like the one in the link you posted really well. build your frame work, then rafters, decking, trim, then roof.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
MTN REMODEL LLC (08-24-2014)
Old 08-24-2014, 11:37 PM   #12
Rewards Points: 220
i have a hip roof, and i wouldn't want that for the door.
the other option is a flat slopped roof.
something like this http://groovexi.com/wp-content/uploa...tion-ideas.jpg
i'm not painting the deck, transparent stain only. i like to see the wood.
so, if i didn't use treated. what would i do with the posts ? as they would be on the piers. the brackets good enough ?
Old 08-24-2014, 11:46 PM   #13
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Well.... That is even easier.....
MTN REMODEL LLC is offline   Reply With Quote
Old 08-24-2014, 11:53 PM   #14
Use redwood posts instead, then use a clear finish.
of course the clear needs to be renewed more often, because it does not last long with U V on it.
But you still get to see wood, not paint.
ED
Old 08-24-2014, 11:57 PM   #15
Use spar varnish/poly
Hard start cap blew, any thoughts? sidejobjoe HVAC 4 06-24-2014 07:05 PM
Bathtub Faucet - Hard Line or Flex Line? ddawg16 Plumbing 7 05-17-2014 03:24 PM
AcroTilt Vinyl window is Hard to push up. Sellncars Windows and Doors 2 05-30-2011 08:53 AM
Hard Duct. Garalee HVAC 4 03-08-2011 04:41 PM
Diference between Fiberglass and Hard Foam shumakerscott Roofing/Siding 3 09-06-2008 01:16 PM
