Joists - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 08:01 PM   #1
Cool
joists
how to fix a cut joist?
clsals is offline   Reply With Quote
Old 12-13-2010, 09:45 PM   #2
Registered User
Termite's Avatar
Moved your post to the carpentry forum.
Your question is incredibly general. Kind of like saying "how long is a rope". If you would describe all the details of the joist and the specifics of the cut, you're more likely to get a helpful answer. Pictures are worth a thousand words.
Some parts of some joists can be cut or notched without any real ramifications. Other cuts can lead to total failure. Totally depends.
Old 12-13-2010, 10:35 PM   #3
Rewards Points: 5,336
Post a picture.
Ron
Old 12-15-2010, 10:31 AM   #4
Drywall contractor
Rewards Points: 1,070
Agreed a pic would help. Basically you'll want to "scab" a length of lumber of the same dimension on one or both sides of the cut joist. How long the piece needs to be and whether you should do both sides will depend on how the joist is cut, what's in the way, etc. And it may be you need to "header" the cut joist off due to why it was cut. Picture please....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-15-2010, 12:38 PM   #5
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I would rather continue the discussion on the length of rope.
WirelessG is offline   Reply With Quote
Old 12-15-2010, 01:29 PM   #6
Joists
Yeah agree. I visited an older home for sale to find the owner had cut a joist to install plumbing. the house is 32 feet wide. There is a main bearing wall at the center (16 feet) of the house. THE JOIST IN QUESTION WAS CUT RIGHT THROUGH 8 feet from the bearing wall. The joists are 16" centers.
Old 12-15-2010, 01:56 PM   #7
the Musigician
DangerMouse's Avatar
Originally Posted by thekctermite View Post
"how long is a rope"?
Not one inch longer than it needs to be!
They also have wraparound steel re-enforcers that bolt to the joists and carry the load around the hole(s).
DM
Old 12-15-2010, 02:44 PM   #8
So you have no pictures of the offense?
Ron
