Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-31-2009, 10:23 AM   #1
d78
Default Joist spacing
This is a joist spacing question. I am using rough sawn 3x10 floor joists, spanning 11 feet. One end rests on the sill, the other attached to a 6x10 center beam with double joist hangers. The flooring will be 2x6 tongue and groove. The joists and underside of the flooring will be exposed so I'd like to use as wide a spacing as practical. Would 32"oc be ok or should I go with 24"oc? All materials will be white pine. Thanks for your help.
d78 is offline   Reply With Quote
Old 08-31-2009, 02:51 PM   #2
Western white pine (surfaced dry or surfaced green. used at 19% max. moisture content---
#2, 1-1/2"net. and 4" and wider, tongue and groove, with 925 fb---will span 4.5' (54") and safely carry 40# per square foot. This from the 1988 UBC. You could ask a lumber yard for the current code, if changed at all.
Be safe, G
GBR in WA is offline   Reply With Quote
More On This Topic
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
Trees are beautiful and useful elements to any landscaping design. Removing a tree to make room for your deck project is not only unnecessary, but may cause more trouble for your yard in the future. Instead of removing the tree, include these majestic... Read More »
We are standing in a room that used to be a carport when the house was originally built and somewhere along the line one of the owners has turned this in to a living quarters, whether it be a bedroom or a family room or whatever and we are in the process... Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
We are going to talk a little bit about the demolition that we had to do to get started with this project. As you can see this wall along here has been exposed. You can see the 2x6 construction. We came in and decided where the new door should be into... Read More »
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 11:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 04:18 PM
Deck Joist Spacing udlooz Building & Construction 19 11-05-2008 08:42 PM
Joist, rafter, and stud spacing for shed? Badfish740 Building & Construction 2 10-27-2008 06:12 PM
How to calculate joist spacing??? jayp Building & Construction 3 06-06-2008 08:17 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
