Joist Hanger Question? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 10:40 AM   #1
The local hardware store doesn't carry 1 1/2" joist hanger nails. Can 1 1/2" masonry nails be used instead for a LUS24 hanger?
Corrosion resistance isn't a problem since it's in a garage.
mopowers is offline   Reply With Quote
Old 08-19-2010, 10:56 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Hardware stores generally do not carry much in the line of building supplies. Most joist hangers along with the nails are sold at local Lumber Yards or Building Suppliers.
In your case, if your local yard is not convenient, I would not be afraid to use Masonry Nails.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
mopowers (08-19-2010)
Old 08-19-2010, 11:43 AM   #3
Registered User
Rewards Points: 5,516
No. That LUS hanger requires 10d----3" x 0.148" diameter nails. You cannot substitute 1-1/2" or concrete nails with a smaller head, even for a load reduction. http://www.strongtie.com/products/co...ace_ss-df1.asp
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 08-19-2010, 11:54 AM   #4
Be safe, Gary
It will be attached to a 2x4 on the wall, so 1-1/2" 10d are fine according the thier website (with load reduction) http://www.strongtie.com/products/co...rs/LUS-HUS.asp
"With 2x carrying members, use 10d x 1 1/2" nails into the header and 10d commons into the joist, reduce the load to 0.64 of the table value. "
The masonry nails they have at the store have as large of a head as a 10d.
The Following User Says Thank You to mopowers For This Useful Post:
Gary in WA (08-21-2010)
Old 08-19-2010, 12:05 PM   #5
These are the type of masonry nail they have:
Can these used used in place of 1-1/2" 10d's for a garage shelf??
Old 08-19-2010, 12:56 PM   #6
Rewards Points: 5,336
Will the masonary nail with that type of shaft hold as well as the designated fastener?
Might it not pull out more easily?
Finding the correct nail isn't a Herculean task, why bother with this?
Ron
Ron
Old 08-19-2010, 03:42 PM   #7
Ron
Ron
You're right. I was just being lazy because I didn't want to drive 30 minutes for a 1lb box of joist hanger nails. Oh well...
Old 08-20-2010, 10:25 PM   #8
295yards's Avatar
What are you trying to pull here?
It's funny I've done it too. You know you should probably just do it the right way but maybe someone has done it that one way and you're hoping they say " oh yeah, no problem"...instead you get the answer you may have known all along.
295yards is offline   Reply With Quote
Old 08-20-2010, 10:38 PM   #9
Yeah, you're right. It just sucks cause it costed more money to drive to the lumber yard than the damn nails themselves.
Old 08-21-2010, 02:25 PM   #10
Registered User
You are sharp! I'm glad you caught that. "With 2x carrying members, use 10d x
  • 1 1/2" nails into the header and 10d commons into the joist, reduce the load to 0.64 of the table value."
I was thinking the joist nails could not be substituted because of the needed length for the shear required, not the header nails..... In my seismic zone, the truss companies require 2x4 shear hangers on the hip jacks, with real 16d driven through and bent over for shear on the single member 2x hip master. Forget the doorways or under a table, stand under a hip set!
Thanks for pointing that out.
Be safe, Gary
Old 08-21-2010, 02:47 PM   #11
Rewards Points: 154
Simpson has recently come out with these screws that can be used on joist hangers. They can be more convenient to install and hold down better, though pricey.
http://www.strongtie.com/products/co...-loadrated.asp
ovahimba is offline   Reply With Quote
Old 08-22-2010, 01:56 AM   #12
Tool Geek
PaliBob's Avatar
Originally Posted by ovahimba View Post
..... They can be more convenient to install and hold down better, though pricey......
Mike Holmes may feel vindicated as he has been using screws in hangers for years although he won't like it that drywall screws are NOT approved. I saw one episode where one of his crew used a drywall screw to connect a steel stud to a steel track .
Disclaimer
& Stay Safe
.....Bob Lavery
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 02:07 PM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
Joist question - sistering tpagel Carpentry 5 03-09-2009 08:11 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Sill and Joist Question jkspup22 Building & Construction 5 03-26-2008 07:18 PM
