Joist Bracing/Blocking Q's - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 07:46 PM   #16
Originally Posted by GBR in WA View Post
Are the walls bearing or just to add insulation behind and hide the concrete footing? How wide is the bottom plate?
Gary
sorry, my drawing is obviously not to scale. This was done for non-bearing partition walls, and on walls to hide plumbing and footing. The bottom they used 2x2.
acerunner is offline   Reply With Quote
Old 09-17-2010, 09:52 PM   #17
Registered User
Rewards Points: 5,204
That will work as long as it passes Inspection.
Gary
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 10:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 03:18 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
