Joint Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 06:10 PM   #1
AJ1
Joint Question
Newbie to the forum, moderate woodworking skills (provided nobody has to look at the end product in bright light, that is).
I am in the process of redoing the space under the basement stairs and am putting in a set of built-in corner shelves. Space is limited, ie - as are my shop options.
I am using a project board from the local lumberyard - pine glued together in 16" and 20" widths. For a number of reasons, I am going to have to fasten two board edges together, one end and one side, as a shelf. The question becomes 'how'.
I have used splines before but have two concerns. The first is strength, even when glued, in the 'edge' board - the possibility of it splitting along the grain. There will be cans and such on these shelves, so some strength is required. The second is of course cutting the grooves - it's a table saw (experiments so far seem promising) or hand tools.
Not much experience with biscuits - no joiner as yet.
I've used dowels before but alignment is always a pain on such large pieces.
I had a thought a few minutes ago about a half lap joint, but have never tried it on such a scale.
Any advice would be welcome.
AJ1 is offline   Reply With Quote
Old 03-23-2011, 06:14 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Biscuits would result in the strongest joint I think. You don't necessarily need a jointer or a biscuit cutter to use biscuits if you have a table saw.
How about a simple cleat or two underneath?
XXX
Old 03-23-2011, 06:16 PM   #3
AJ1
Thanks. I had thought of cleats underneath but would, if possible, prefer to avoid them. I suspect that may be a vain hope.
I've never heard of using biscuits with a table saw. How's that done?
Old 03-23-2011, 06:47 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Set the table saw rip fence so that with your boards (on edge) the blade is centered with the edge of the board(s). Clamp a board to the fence over the (lowered) blade and raise the blade into the board. Make a series of these cuts in both pieces to be joined.
The biscuits radius doesn't necessarily have to match the radius the blade will cut.
You could cut a continuous groove but that may only weaken the joint.
Works in a pinch or in the absence of the proper cutting tools.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
williamwiens (03-27-2011)
Old 03-23-2011, 07:08 PM   #5
Experienced
Jackofall1's Avatar
Hello and welcom AJ1 to the best darn DIY'r site on the web.
Bisquets, is one way to go, you know that dowels are a pain, do you have a router? how about a lap joint?
Mark
Old 03-23-2011, 07:17 PM   #6
AJ1
Thanks.
The router is an idea.
I have been thinking of a half-lap joint. The joint itself should be good and strong, given the crossing grains. Maybe that's the way to go.
Old 03-23-2011, 07:34 PM   #7
AJ1
Bud Cline - Thanks. I will give that a try with some scrap.
Old 03-26-2011, 12:44 PM   #8
Rewards Points: 5,336
If you have a router with a slot cutter bit, that would work. But instead of bisquits, you would use a spline in the slot. If the edges are exposed, don't cut all the way to the ends.
You can do the same thing with a table saw.
Ron
Old 03-26-2011, 02:10 PM   #9
AJ1
Ron6519 - Thanks very much.
Old 03-26-2011, 05:09 PM   #10
Civil Engineer
Rewards Points: 4,526
There are many joint choices. If you have a Kreg jig, you can use pocket holes. If you have a router, you can use a half lap, spline, or biscuits. If you have a biscuit jointer, you can use biscuits. You can also use a box joint with either a router or tablesaw. If the pieces will not be visible, you can glue and screw the joint. The only joint I would truly stay away from is dowels, not very strong compared to the options.
Daniel Holzman is online now   Reply With Quote
Old 03-27-2011, 11:26 AM   #11
AJ1
Daniel Holzman - Thanks
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
concrete joint leaking billie_t Building & Construction 3 07-24-2008 09:10 PM
hrv question indep HVAC 3 07-17-2008 11:39 PM
joint compound question golfer General DIY Discussions 3 01-09-2006 07:19 AM
