Joining Wood Using Pocket Holes (2 Methods) - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-23-2014, 07:18 PM   #16
Rewards Points: 326
thanx all...
my application today, is building my first outdoor farmhouse table. I have roughly 24 pocket holes to make. I can drill on an angle - but what if i get that wrong... or i get the jig... and voila!
that's why i asked about the two methods - countersink on an angle versus kreg jig.
i definitely want to mortese and tenon - but dont have the time to learn the skill right now - wife and kids naggy me on when the patio table will be built. if i go the M&T route - i think i will have it done by winter! hehe
Amitabh is offline   Reply With Quote
Old 06-23-2014, 08:37 PM   #17
Rewards Points: 1,488
Kreg jig, glue and screw, or biscuit joint, glue and clamp.
In my opinion, it the only way to go if you want it done quick and easy...
ktkelly is offline   Reply With Quote
Old 06-24-2014, 01:54 AM   #18
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Amitabh View Post
..........i definitely want to mortese and tenon - but dont have the time to learn the skill right now.........
I can't help with the time factor but Festool has a Tool that somewhat reduces the learning time but it is Recommended Just for Pro's .
http://www.garymkatz.com/ToolReviews/festool_domino.htm
.........Here is more on Mortise & Tenon:
http://en.wikipedia.org/wiki/Mortise_and_tenon
For what I mostly do repairing furniture for friends the one hole Kreg Jig works best for me.
Pocket Hole Joinery dates back to ancient Egypt.But then without pocket screws they had to use wooden dowels in an angled hole:
http://en.wikipedia.org/wiki/Pocket-Hole_Joinery
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-24-2014, 07:28 AM   #19
Rewards Points: 326
Hi PaliBob
Thats an amazing tool - well out of my budget, considering i am looking at a $5 option vs. $45...
if i becoming a carpenter on the side for my friends, i might look at this.
but baby steps...
is it okay to screw the table together to see the fit and then unscrew, to stain and screw again (with glue)
Old 06-24-2014, 12:40 PM   #20
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
Hi PaliBob Thats an amazing tool - well out of my budget, considering i am looking at a $5 option vs. $45... if i becoming a carpenter on the side for my friends, i might look at this. but baby steps... is it okay to screw the table together to see the fit and then unscrew, to stain and screw again (with glue)
One option....make the screws/bolts a decorative feature. It really opens up your options on design.
ddawg16 is online now   Reply With Quote
Old 06-26-2014, 01:57 AM   #21
Tool Geek
PaliBob's Avatar
.......is it okay to screw the table together to see the fit and then unscrew, to stain and screw again...... (with glue
This thread was started on pocket joinery. Now to go to the next step and build your table I suggest that you start a new thread on how to build the table. We don't know your skill level,, what tools you have, what kind of wood, what size is the wood and the table and what do mean by a Farm Table? Is that like a picnic table with built in benches on two sides?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-26-2014, 03:37 AM   #22
Rewards Points: 2,058
thanx all...
That outdoor table would be a perfect project to hone your Kreg skills if you use outdoor screws. Possibly practice on some scrap lumber as there is a slight Kreg learning curve also.
Being mortice and tenon joints are so sensitive to expansion and contraction in my opinion the Kregs will excel in this outdoor application from frame joinery to top plank assembly to attaching bread board ends.
Come back with a picture when finished.
Old 06-26-2014, 09:28 AM   #23
Rewards Points: 326
i will thank you
Old 06-26-2014, 12:34 PM   #24
Ole Wood Worker
BigJim's Avatar
Rewards Points: 776
If you plan to use your pocket hole jig several times you could make a jig like the one I made below. You do not have to use the pocket hole screws, just don't over tighten them. On a table you need to do the pocket hole screws from the bottom of the table top. Another thing to know about joining wood pocket hole method, it is a good idea to use a C clamp to hold the pieces flush while installing the screw, the wood sometimes tries to ride up because of it being screwed at an angle.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
oh'mike (06-26-2014), PaliBob (06-26-2014)
Old 06-26-2014, 01:22 PM   #25
DIY staff
Rewards Points: 7,174
I got one for Christmas a year ago---wow--great tool---I tend to be the last guy on the block to get try new methods---but those are great.
Old 06-27-2014, 12:53 PM   #26
Rewards Points: 326
what is the material called that locks the wood in place. everything else looks like wood and screws.
Old 06-27-2014, 01:27 PM   #27
JOATMON
ddawg16's Avatar
In still very find of my biscuit cutter
Old 06-27-2014, 07:34 PM   #28
DIY staff
Toggle clamp or push pull clamp
BigJim (06-28-2014)
Old 06-28-2014, 01:03 AM   #29
Ole Wood Worker
BigJim's Avatar
Rewards Points: 776
Sorry to be so late answering your question, I have been carving a wooden P-51 Mustang airplane.
Mike answered right, it is a toggle and the rest is wood, saved a little pocket change and it works as well as the store bought ones. LOL
Jim
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (06-28-2014)
Old 06-28-2014, 07:23 AM   #30
DIY staff
Jim--my shop has many 'temporary' jigs like that one--
Often, I'll rig up something, figuring that I'll buy a fancy store bought one if it works----and then 10 or 15 years go by and I'm still using the home made rig---
BigJim (06-28-2014)
Sealing 5/8" holes in wood air return pex006 HVAC 3 01-12-2014 10:56 PM
wood dowels good for repair bad screw holes? darsunt Carpentry 10 08-12-2011 06:42 AM
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 11:50 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
Installed pocket doors, now how do I remove the wood to install the hardware amdspitfire Carpentry 8 11-21-2008 01:43 PM
