Joining Wainscot At A 45 Degree? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 11:03 PM   #1
Rewards Points: 150
Joining wainscot at a 45 degree?
I am in the process of installing "white ice" wainscoting on the apron of drop in whirlpool island. It is a corner unit with the 45 degree corners. I am gonna use the wainscoting on the apron and tile the deck. Anyone have any tips on joining the 45's together. I am gonna tile and try to use a cap piece on the deck.
Thx. Mike
MikeVila is offline   Reply With Quote
Old 04-09-2009, 04:35 AM   #2
Remodeling Contractor
Just cut the 45 degree pieces at 22.5 degrees each. Caulk the seam to protect from moisture.
Old 04-09-2009, 05:59 AM   #3
CrossWorks's Avatar
Rewards Points: 150
One other sugestion: Since you will be adding tile and mostlikely a trim piece at the top as a border, cut your sheets of white ice (Home Depot material??) about a 1/2" less than the total height of the framing, and plan to set it up a 1/4" from the floor sheathing and down 1/4" from top of framing. This will allow you a little wiggle room to fit those corners good and tight. Also keep in mind that you need to cut those sheets from the back side so as to avoid any chipping.
Reason being; the teeth on circular saws circulate upwards, and with that in mind, if your cutting the material "good-side-up", you may risk chipiping the finished surface.
So make sure you cut your 22.5 degree angle "FIRST!!" then measure for the lenght and make that cut. And both cuts from the back side. Starting from the left and working around to the right:I would suggest making two sample pieces that have the angles on them, and bring them together at the outside corner first so they match perfectly. Once you have a perfect fit, hold in place the piece that sits on the left side and measure from the end to the angle to get the lenght for the left side piece. Then put the two sample pieces together again at the right side angle and hold the piece on the right and measure from the left angle to the right angle piece. This gives you the length for the center piece. Cutting the middle piece to the exact length will be your challenge for the day, since your making both cuts from the back side. Then finish your last piece on the right.Also keep in mind to use a clamped straight edge for making these cuts.
I'm assuming all this is "Sheet Material" based on the description of white ice. Besides, I don't think there is a species of white ice tree out there to make wainscotting panels... Be a bit brittle don't ya think!
Good luck!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-10-2009, 12:11 AM   #4
Rewards Points: 150
Thx so much for taking time to explain it in detail. That's pretty much what I thought just wanted to get an expert opinion and some pointers.
Old 04-10-2009, 05:53 AM   #5
CrossWorks's Avatar
Rewards Points: 150
No problem Mike.
Also, something I noticed and wanted to touch on. It appears your electrical box is set way in the back on the right side. I hope that is the correct spot for the power source. It seems it would be a challenge to plug in the motor if that location is correct.
Just in case, verify the location of the plug on whirlpool tub. Otherwise if possible, try to locate the box closer to where you can reach it to make it easier to reach.
Old 04-13-2009, 09:30 PM   #6
That white ice stuff, IIRC is an MDF based material from H.D. or Lowes...I would think carefully about using it there. Water and MDF don't mix, let alone warm steamy water... If you do use it, get a good oil based primer and PRIME all sides of the white ice....front, back, joints, sides etc etc...everything. You need to try and seal out that warm water vapor.
TBFghost is offline   Reply With Quote
In a room with painted wainscot what color do you paint doors cindyb861 Painting 1 04-05-2009 06:51 AM
90 degree turn in horizontal 3" main drain wildbilly Plumbing 2 03-14-2009 05:52 PM
Wainscot molding issues cmdrico7812 Remodeling 2 02-01-2008 12:54 PM
90 degree end of lineset?? davidc HVAC 2 05-25-2007 12:46 PM
Joining cpvc to copper? randalg Plumbing 5 12-03-2006 07:42 AM
