Jamb Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 01:11 PM   #1
Rewards Points: 396
jamb question
I removed a portion of a wall and am going to add 1x jambs to the jack studs and under the header. When I add the 1x4 jamb it will only cover the 2x4's and not the edges of both sides of the drywall. Do I have to get a 1x6 and rip it to fit?
detroittigerfan is offline   Reply With Quote
Old 01-25-2014, 01:17 PM   #2
kwikfishron's Avatar
Rewards Points: 824
5-9/16" is usually the number your after and may not happen with a 1x6
kwikfishron is offline   Reply With Quote
Old 01-25-2014, 02:45 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
I think your mistaken, 4-9/16" is typical jamb size
Millertyme is offline   Reply With Quote
Old 01-25-2014, 02:52 PM   #4
Rewards Points: 824
I think you're right...I must have suffered a brain dead moment.
Old 01-25-2014, 03:23 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
Lol, it happens
Old 01-25-2014, 03:40 PM   #6
Rewards Points: 14,026
You can buy precut jambs at any lumber yard or even Lowes or HD.
They will come with rounded edges, cut to the right width and will already have a dado at the top where the top one fits into.
Old 01-25-2014, 05:37 PM   #7
Rewards Points: 396
if not I would just have to rip down a 1x6 to fit?
Old 01-25-2014, 07:10 PM   #8
Stairguy
Millertyme's Avatar
Rewards Points: 508
Yes. Are you adding a door or is it just a cassed opening?
Old 01-25-2014, 10:20 PM   #9
Your choice, have to pay top dollar for clear pine, spend the time to sand the cut edges, round over the outside edges, cut a dado on the ends.
Or just buy the premade jambs and just have to cut to length.
http://www.homedepot.com/p/American-...FSET/202083257
Old 01-26-2014, 10:14 AM   #10
Rewards Points: 396
If your height is more than 80" these jambs wouldn't work anyway.
Old 01-27-2014, 08:58 AM   #11
AHH, SPANS!!!
Rewards Points: 1,166
measure the thickness of wall from outside edge of drywall to outside edge( or do you have plaster??) rip jamb the size that you measure plus add 1/8". if you come up with 4 1/2" thick then make your rip 4 5/8" for all three pieces of jamb. check measurement in multiple spots around opening, it can get thicker near header area...
hand drive is offline   Reply With Quote
Just a quick+easy question to pest control workers and/or owners...pls read..... jkls Pest Control 2 10-09-2012 10:53 PM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 08:30 PM
Rotten door jamb and king/jack studs bob22 Carpentry 7 12-06-2008 05:50 AM
Window Jamb question groundtrac Carpentry 7 11-23-2008 08:09 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
