Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-30-2008, 09:05 AM   #1
Gusaroo's Avatar
Are Jack Studs necessary on partition walls?
I am throwing up some partition walls to divide up a large room and am wondering if I can save a few bucks by not using jack studs in the door ways. Obviously, the walls are not load bearing, but I was wondering if the doubled up king stud and jack stud are needed to add rigidity for the swinging door frame or if just a single stud opening is strong enough for the door opening. Thanks guys.
Gusaroo is offline   Reply With Quote
Old 11-30-2008, 09:15 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Jack studs are not necessary from a structural standpoint. However, you will want to install them for several other reasons.
1.) Door installation: They strengthen a door opening for an actual door installation.
2.) Sheetrocked opening: They strengthen the opening, especially if that opening will be wrapped in sheetrock. Pretty much, you are going to see cracked corner bead over time, if you don't double the sides.
3.) Wood Trim-work Installation: You will need the 3" of wood (1.5"+1.5") around the sides and top edges, in order to attach the wood casing trim work's edges. With only 1.5" of lumber, there will not be any wood behind your standard 2.5" wood door casing for a nail to set into.
- Build Well -
Old 11-30-2008, 09:41 AM   #3
Gusaroo's Avatar
Thx, I didn't even think of the trim. Thats good info.
Old 11-30-2008, 09:56 AM   #4
Drywall contractor
And two studs nailed together have much less chance of twisting/warping somewhere down the line and causing problems with doors opening and closing properly. The few dollars saved is hardly worth it....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-01-2008, 05:48 PM   #5
You dont actually have to use jack studs though. Just double up two main studs then frame the door opening down.
DIYJIMBONL is offline   Reply With Quote
Old 12-01-2008, 06:34 PM   #6
Drywall contractor
Yeah, but it only takes a few more minutes to do it correctly.........you have to frame some sort of header anyway. Put your jack studs in, double 2"x4"s on top of them, "cripple" studs between the top plate and double 2"x4"s, and you're done.
Old 12-02-2008, 04:04 PM   #7
The way I described is correct. There are several correct ways to frame a door opening. Pros and Cons to both. The way i described there is less chance of twisting because two main studs are nailed togetther and to the top plate. The way you describe there is only one stud nailed to the top plate.
Old 12-02-2008, 04:24 PM   #8
Drywall contractor
The way you described is not correct for any load bearing application. In 35 years in the trades, I have never seen a door framed the way you described in new construction. All use jack studs whether in a load bearing or non load bearing wall. The method I described with a header and cripple studs above gives solid, double stud framing to the top plate. Your method will suffice for non load bearing.
Old 12-02-2008, 05:03 PM   #9
Before things get too heated...the original post was pertaining to non-load-bearing walls/partition walls.
- Build Well -
Old 12-02-2008, 05:13 PM   #10
Drywall contractor
Understood Atlantic, and no offense meant DIYJIM. My idea of "correct" and his differ....
Old 12-02-2008, 05:51 PM   #11
Custom Cabinet Maker
Hold up here folks!!!!!! What is this stealing MY studS
Jack
skymaster is offline   Reply With Quote
Old 12-03-2008, 09:56 AM   #12
Exactly!
Old 12-03-2008, 10:52 AM   #13
Drywall contractor
Your method will suffice for non load bearing.[/quote]
I said his method would work. No harm, no foul.
Old 12-03-2008, 10:58 AM   #14
FYI For the time it takes to get on your computer and enter your question in the chat forum putting in a king and jack stud and proper header would be done.
Fixing it after the fact becomes a pain in the a$$ (from own experience)
mfleming is offline   Reply With Quote
Old 12-06-2008, 06:39 AM   #15
Do it right. There is so little to be saved by skipping a few boards that it isn't even worth considering.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Can I use Microlam for Jack Studs? (Enlarging Door Opening) Kevin8565 Carpentry 7 04-30-2008 01:27 PM
Jack Studs Clutchcargo Building & Construction 7 09-06-2007 07:10 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
