J Trim On Aluminum Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 12:55 PM   #1
Unhappy
J trim on aluminum siding
new windows were installed couple of days ago. the front windows are with j trim. the j trims are not installed flat on the siding. There are gaps on the side & the top portion. They install a vinyl filler at the bottom and it now looks straight.
However the side portion warps as well as the top one. according to the contractor this is perfectly normal because we have aluminum sidings. Is this true? What remedy can be done to fill the gaps? I am afraid that these gaps are invitation for insects to build nest inside. Thank you
J trim on aluminum siding-dscf3321.jpg   J trim on aluminum siding-dscf3324.jpg   J trim on aluminum siding-dscf3314.jpg   J trim on aluminum siding-dscf3330.jpg   J trim on aluminum siding-dscf3319.jpg
rossana is offline   Reply With Quote
Old 05-15-2011, 04:59 PM   #2
Rewards Points: 1,668
Pics might help.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
rossana (05-16-2011)
Old 05-15-2011, 06:08 PM   #3
Custom Home Builder
Doesn't sound right but post a few pics if possible.
What is behind the siding?
Asbestos shingles? Plywood? Cedar clap?
Aluminum siding or vinyl?
Existing or new?
thomasjmarino is offline   Reply With Quote
The Following User Says Thank You to thomasjmarino For This Useful Post:
Old 05-15-2011, 08:51 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
this is not normal,tell them they need to install the same type of peice that they installed on the bottom to the sides and top
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Old 05-15-2011, 09:42 PM   #5
pictures
pictures are in the album. we have an existing aluminum siding
Old 05-15-2011, 11:41 PM   #6
oh...2 1/2''j channel,that will do that,doesn't really matter what type of siding you have,the face of this material is very flimsy...i suppose your installer could try to ''shim'' it out some to try and straighten it somewhat but it is what it is ...sorry
Old 05-16-2011, 08:53 AM   #7
will it be much better if the trim is wood? thank you
Old 05-16-2011, 07:50 PM   #8
depends on the installer,looked like he did a nice neat job,but like i said the wide face j is flimsy at the face and will tend to ''warp'' like that
it can be done with wood
Tags
aluminum siding , j-trim , vinyl window , window
installing vinyl siding over aluminum siding brad7359 Remodeling 8 07-24-2010 06:28 AM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
