Issue! Do I Install Chair Rail At Same Height As Hallway Rail? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 08:37 PM   #1
Rewards Points: 97
Issue! Do I install Chair Rail at same height as hallway rail?
So the main point and focus is that we are cleaning up the house to sell
and move up.
So, Living room is almost complete and I started on the dining room today.
After plaster, sanding and paint I went to Lowes (Only thing close) and
picked up some Chair Rail so I can create some wainscoting.
There is only one halfway (of 2) that has wainscoting and I measured and its
installed at 38" at top!
6" baseboards..... Crown Molding.
It's not THAT bad because I have 9ft ceilings. However, I know the "standard"
is 34"-36" even though it's actually suppose to be 1/4 of the wall height....
Anyway....
I was thinking 34. But, I don't want it to be way off from the hallway (which isn't connected to the dining room) so I was thinking I should raise it to 36"
so that it isn't that far off... 38 is way too high... I guess until I researched chairrail history i didn't realize how low it was actually suppose to be.
Anyway, Main point,
Home built in 1938, Hallway rail is 38" top, I don't want to do that...
How much lower can I go without it being an issue.... 36"? Seems high still....
Also for selling home!
Thanks.
Here is picture of the currently hallway, and the dining room.
Looking for possible help within an hr or two/three.
I know short notice, No biggie.
If not I'm just installing between 34-36.... :shrugs:
Also, they dont match but what is in the hallway seems really cheap...
Just the dining room chair rail itself cost me $30 a (12ft) section....
Pics.
Hallway....
Dining room.... Chair Rail, Wainscoting, Painting to be done....
Chair Rail
With paint, The top will be the red it is in the photo. ( But a new coat of Satin.... )
The bottom surrounding the pictureframes will be Tollbooth ( What's in the living room ) and then inside the frames will be red like the top...
I thought this would look nice and tie the dining room in with the living room that you can see to the left of the dining....
Firefighter3244 is offline   Reply With Quote
Old 04-30-2013, 09:27 PM   #2
That looks like Howe casing.
g1hrtr is offline   Reply With Quote
The Following User Says Thank You to g1hrtr For This Useful Post:
BigJim (04-30-2013)
Old 04-30-2013, 09:47 PM   #3
Rewards Points: 97
It is. Is that bad? lol,
It was next to the chair rail stuff and I just liked it more.
I plan on panting the flat part the same as the wall color. Blending it in like I did with the fireplace mantle....
Old 04-30-2013, 10:17 PM   #4
I don't think I've ever seen it used as chair rail or in wainscoting. They have a "Baby Howe" that is not as wide. If you insist on that profile, it would probably be a little more proportional.
Old 04-30-2013, 10:23 PM   #5
Rewards Points: 97
Well, It's too late for that. I already bought it and cut it...
I guess we'll see how it looks.... I liked it as did my wife so
I'll know tonight once it's up, and I have to go back tomm for the
trim to create the picture frames.
I'm going with 36" with the height.
Old 05-01-2013, 09:28 AM   #6
Too Short? Cut it Again!
You should do what is going to look right visually here and you are confusing a couple of things.
Wainscoting can be any height but you want it to look substantial enough to visually support what is above it in a room---1/4, 1/3 or whatever. If it is too short and a much lighter color than the wall and crown on top of it, it looks like their is too much weight on top of it and whether you realize it or not, you are made to feel uncomfortable in a room like this. As if it would collapse or something.
Chair railing was popular to protect plaster walls from, of all things, the backs of chairs bashing gouges in it. It too looks weird if it is positioned with no relevance to chair backs in a room.
The final trim you see a lot in antique homes is picture frame trim around the top---separate or part of the crown installation. People didn't use to have access to modern picture frame hooks and things made for plaster walls so pictures were hung from clips that engaged the frame molding around the top and that had wires coming down to hold paintings. That is why there is that 1/2" gap between the ceiling and the molding. It provided space to move fit and move the clips along the trim.
Don't over think this. Just make it look right, sell the house, on move on to your next project.
Old 05-02-2013, 02:35 AM   #7
Rewards Points: 97
Okay thanks.
Yeah, It took a good bit of work to get it to look right. Considering the walls aren't even, ( Plaster ) The floors aren't level to each wall, The walls aren't square etc made it a task....
Had I just did everything at x inches it would have looked horrible and way out of level etc.... Anyway, hope the colors work. The bottom is what the living room is...
Still have to paint and caulk the trim/chair rail... And start on the picture frame wainscotting.... Thinking about painting the intr of the frames red to match the top.... Good/bad?
It's averages 36" top of chair rail.... So it looks good imho. Not too high. Not too low.
Pics/
Excuse the shadows, the light source is on the floor casting shadows....
I'm happy with it, Considering I've never done any of this before.... ( 1st home and in my early 20's )
I had to use trim screws with the adhesive on the back because of the waving of walls to keep it in place.
Bottom Primed and ready for paint
A close up of the corners.... (Ignore the shadows again...)
Still gotta paint the trim, chair rail and caulk and do the wainscoting picture frames but it looks pretty good I think.
Other half is the same...
Old 05-02-2013, 07:25 AM   #8
It looks good I see why you went with the big rail, with all that big trim around the windows and doors and the baseboard very nice. It almost looks small but it's a good size ties in nice
nightriderrv is offline   Reply With Quote
How to attach chair rail tile with hollow back? BlueBSH Tiling, ceramics, marble 0 09-26-2012 03:21 PM
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-20-2011 12:51 AM
Painting/staining crown moulding and chair rail Gypsy601 Interior Decorating 8 07-05-2011 04:51 PM
New Trimwork: Chair Rail, Wall Frames (Wainscoting) And More Rock8Reno Project Showcase 24 04-07-2011 08:15 AM
Chair rail dead end treatment? bergerdude Carpentry 10 07-22-2010 03:51 PM
