Interior Walls & Gambrel Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 12:39 AM   #1
Interior walls & gambrel ceiling
First of all, I want to say thank you in advance to anyone who can help me solve the following problem.
I recently purchased a 14 x 40 foot lofted barn style shed building with a gambrel roof and all of the interior is rough framed. I am wanting to convert this building into a small guest cabin. I am ready to start framing interior walls and here lies my dilemma.....how does one attach an interior wall to the gambrel ceiling? I have researched this extensively only to find no real answers other than the wall has to be a rake wall, which is understandable. Do I attach the interior rake wall to the existing trusses (which are not flat, like a top plate) or do I attach a new top plate to the ceiling? The roof does have sofits along the eaves and also a continuous vent along the pitch of the roof. Any help or suggestions?
Cveroline is offline   Reply With Quote
Old 01-27-2011, 07:48 PM   #2
It's probably easiest to build a regular frame wall, then fill in the top, sides. Normally I wouldn't advise that becaause you need something top to bottom for strength, but at only 14' (probably less with the steep roof sides, your top plate(s) can be one piece. That'll be pretty decent rigidity unless you'll constantly be slamming a heavy door. If you use sheetrock, span across the top plate to avoid cracking at the seam and to add strength. If you decide to frame all studs top to bottom, frame in place. Install the bottom plate, plumb up at center and ends, install top plate, then put in your tallest stud first. Then you can measure off of it to layout all the others. If you go that route, DeWalt makes a real nice tool. It's a plumb laser. You set it down on your mark at the bottom and it makes a red spot on the ceiling exactly plumb from there
Dwoodsmith is offline   Reply With Quote
The Following User Says Thank You to Dwoodsmith For This Useful Post:
Cveroline (01-28-2011)
Old 01-27-2011, 10:54 PM   #3
Registered User
Rewards Points: 5,180
For a short length (not height) rake wall, frame it flat be leave the last 3" off the top plate to run the end studs full-height, nailing into ceiling rake plate with blocking between the trusses.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Tags
gambrel roof rake wall
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Raise ceiling in Gambrel roof? charlz Remodeling 1 01-08-2007 07:49 AM
