Interior Wall On Heated Concrete Floor - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 06:02 PM   #16
Rewards Points: 150
Sorry, Kirk, I'm an architect, not a chippy, though that's by no means reflects on sound advice from chippies.. The diagonal bracing is easy and cheap to apply and good insurance to prevent drywall joints opening up in case the wall experiences some movement, especially around door openings, if any. otherwise I would agree with you, it's overkill.
JoJo-Arch is offline   Reply With Quote
Old 09-26-2011, 07:44 PM   #17
Msradell's Avatar
Rewards Points: 258
I guess one question that nobody has asked is what is going to be the framing for the wall? Will it be lumber for the studs or will they be metal studs? I would guess that since it is a commercial application they will probably be metal.
Msradell is online now   Reply With Quote
Old 09-26-2011, 08:55 PM   #18
Rewards Points: 29
You might want to consider adding at several places along the wall a conduit extending down from the top to a 4x4 outlet box for future use. This makes it *real* easy to add speaker wire, network cabling, video hookups, etc., later when and if needed. (Or power, for that matter...)
The outlet boxes can have blank cover plates until you need them. This is especially handy if the walls will be insulated for noise, etc. And EMT and 4x4 boxes are pretty low cost.
I installed several along selected walls of my living room, office, and bedrooms during construction. One of my better ideas...
slickwilliam is offline   Reply With Quote
How does one repair small holes in a concrete floor? CnK of NY Flooring 3 07-23-2015 01:10 AM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Plywood sub floor over concrete slab targeted4u Flooring 9 07-10-2011 10:00 PM
Electrical Cable Run in Concrete Floor john curry Electrical 4 02-16-2010 04:54 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
