Interior Wall Framing - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 06:30 PM   #1
Ord
Interior wall framing
Hello,
I have a garage with 12' walls, and I want to add an insulated partition wall to divide the space. The lumber I have is 2x6 x12'. The bottom of the ceiling joists are actually at 12'8" because the foundation wall comes up 8" above the floor.
So with 1 bottom & two top plates I would be missing 3 1/2" if I use these 2x6s. Would it be OK to use 2x4s on edge to fill in this space? I'd prefer not to have to order 14 foot lengths and cut them.
Thanks!
Ord is offline   Reply With Quote
Old 05-11-2011, 11:13 PM   #2
Rewards Points: 5,336
For this application I would have stacked a 4' 8" wall on an 8 foot wall.
A 2x4 on edge? How would that work, insulation wise?
Ron
Old 05-12-2011, 08:44 AM   #3
Ord
Thanks Ron.
For insulating, I would do it with foam board.
It's probably best for me to just order the longer studs - I would be saving less than $200 by using the wood that is on hand.
Old 05-12-2011, 09:16 AM   #4
Registered User
Termite's Avatar
Just stack two more top plates on there. A couple lengths of plate stock is a lot cheaper than all those new studs you'd otherwise have to buy. Plus it'll be a lot more solid connection to the joists above than you'd get with a 2x on edge.
Old 05-12-2011, 01:09 PM   #5
Ord
Thanks!
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
