Interior Stop Trim After Installing Replacement Windows Not Fitting Correctly - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 08:32 AM   #1
Interior stop trim after installing replacement windows not fitting correctly
I just installed several new double-hung vinyl replacement windows & am having a heck of a time re-installing the trim. All the decorative stops at the head jamb of the window are sitting proud & I need advice on how to thin them.
The primary problem is due to the use of an 'expander' on top of the windows to close the gap between the top of the frame & the head jamb. This is a vinyl channel, approximately 1/16 - 1/8" thick, that holds insulation & slides over the window frame. The result is that 90 % of the frame has one 'elevation' while the top has another. I can get the bottom of the stop trim to sit where it should, but then when I get to the top, it projects (sits proud) past the edge of the head casing. The result looks terrible.
What's the best way to deal with this? Should I try to shave them down using a table saw or planer before I install? (I really don't want to use the planer as many of the stops are only 3/4 inch wide).
All tips & suggestions appreciated!
DyerWolf is offline   Reply With Quote
Old 11-23-2009, 08:39 AM   #2
Framing Contractor
I use a sheetrock knife. It works fine.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-23-2009, 08:44 AM   #3
Next Time...New Build
Rewards Points: 150
So the bottom and sides work fine, but just the top is sticking out past the wall?
If these are normal extension jambs, put a mark on the top of the jam that is flush with the wall and run it through your table saw. Depending on the "decorative" features of the jam, you need to determine to cut the side of the wall or where it rests against the window. Reinstall and put your casing on and you should be good to go.
From your description, it is a little tough to picture but if it is a "normal" window replacement, this should work fine.
RickyBobby is offline   Reply With Quote
Old 11-24-2009, 11:51 AM   #4
Kekeever
Kyle Keever's Avatar
If the wall is not straight where you need to rip the jamb you can rip it to the widest point with a bevel on your table saw and then use your planer to shape to the line. The bevel makes the planing easier. Its some work so if your painting caulk goes along way here.
Kyle Keever is offline   Reply With Quote
Old 11-24-2009, 02:46 PM   #5
A sander will work also.
hayewe farm is offline   Reply With Quote
Old 11-24-2009, 03:35 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Why did you use the head expander? When possible we try not to use them unless the window was ordered too short. If the top interior stop will cover the gap and reach the edge of the window unit itself, i would just cut off the inside lip of the head expander. If not, then you will have to modify the wood as sugested with a table saw.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 11-25-2009, 10:15 PM   #7
PHB Construction LLC
Paulie's Avatar
Ditto on that, never use the header expander for the very reason the thread was started. But I don't throw them all away, the longer ones come in handy for glass block installations.
Paulie is offline   Reply With Quote
Old 11-26-2009, 07:03 AM   #8
Rewards Points: 150
I knew there was a reason I saved all of mine!
TJ_in_IL is offline   Reply With Quote
Old 11-26-2009, 08:50 AM   #9
Paulie's Avatar
I see I got some emails in my account on this subject but unable to open them. I have sent a message to the Mods for a reason. Perhaps my new status on the DYI forum. But at present unable to open them. Happy Thanksgiving!
Old 11-26-2009, 09:26 AM   #10
E-mails are not blocked by us - that goes to the e-mail you entered when you signed up
PM (Private Messages) are not enabled for new users until 10 posts to prevent spamming
If you received an E-mail that there was an additonal post on this thread & there weren't any new comments it was probably a spammer
They add comment & advertising spam that is deleted - but you would still receive the e-mail that a post had been made on your thread
Old 11-26-2009, 09:53 AM   #11
Paulie's Avatar
Thanks Dave, I figured it was the newbie classification. OK this makes 3 posts...
installing trim and moldings faintchimes Remodeling 5 04-08-2017 10:46 PM
Installing Windows after Drywall??? jeepwillies Building & Construction 9 11-22-2006 10:30 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
