Interior Stair Risers Pushed In - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 08:36 PM   #1
interior stair risers pushed in
It's an old house and a couple of the stair risers have gotten pushed in at the bottom where the step and the riser meet resulting in a gap of up to nearly 1" in places. There's no access to the stairs from underneath.
I'm considering two options:
1. attach a replacement riser over the old ones since there's a pretty decent amount of overhang on the steps.
2. embed a screw partway and try to pull out the riser so it meets the step. I don't think this will work, since there are visible nails that have been pulled out along the sides. Also even if I can pull the riser back in place, I don't know how I'd keep it there.
Since I have two steps with the same problem, I'm guessing this can't be all that unusual a problem. Is there is standard way of making this repair?
Thanks very much!
davesink is offline   Reply With Quote
Old 09-26-2011, 08:52 PM   #2
MikeKy55's Avatar
Rewards Points: 254
I'm going to leave it to the professionals here for the repair suggestions. But it sounds like your treads and risers are mortised into the stringers and the stringers are spreading apart a little thus allowing the risers to slip back in the opening. Of course they have had a little help slipping.
MikeKy55 is offline   Reply With Quote
Old 09-27-2011, 03:25 PM   #3
Rewards Points: 5,336
It sounds like the wedges in back of the risers fell out . Older staircases had them under the treads and behind the risers. They were glued in place and 3 penny finish nail driven through the wedge into the stringer. Over time the glue dried out and the constant vibration loosens the nail.
Repair method requires opening the area under the staircase and replacing the wedges.
What do you mean, there's no access under the stairs?
Ron
B. Franklin 1759
Tags
pulled out , riser , stair , stairs , step
Stair Tread and Risers tuchodi Flooring 0 08-03-2011 08:38 AM
Precast seps and risers DETROIT GRIFF Building & Construction 3 04-12-2011 09:06 PM
Tiling Step Risers ironmanDIY Tiling, ceramics, marble 1 03-09-2009 10:01 AM
Staining treads, painting risers QueenL Building & Construction 5 04-13-2008 09:23 PM
3/4" birch ply for stair risers? ACobra289 General DIY Discussions 4 12-15-2007 06:17 AM
