Interior Iron Handrails Came Away From Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 02:49 PM   #1
Interior Iron handrails came away from wall
Hi Everyone,
I have an iron (I THINK it's cast) handrail that, when my son grabbed to pull himself up, came away from the wall. I noticed that there were 2 holes under the bolt plate so I am thinking this happened before.
It looks like the bolt goes right into the drywall and then wood stud behind that.
I tried to reinsert the bolt into the hole and tighten but when I put some force onto the handrail, it slipped out again.
Is there anything I can do (without drilling a new hole) to keep that bolt in? Is there something I can put into the wood (like a drywall version of an anchor) to keep that bolt in there and tight?
I am a newbie so...be gentle!
Thanks all!!
MP
Duhh! is offline   Reply With Quote
Old 06-07-2011, 03:29 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
A couple of things I can think of off hand, put as large a piece of wood in the hole as you can, then screw the bolt back in, it might help if you glued the wood in and let it dry first. Another thing you can do to tighten the screw up is cut a strip of #12 or #10 single strand electrical wire with the insulation left on, insert the wire into the hole as deep as it will go and then reinstall the bolt, the wire will force the screw to make new threads into the wood as well as the wire.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-07-2011, 10:16 PM   #3
the above is a option, woodglue mixed with sawdust works alright, but try using a longer bolt ? so it has something to grab onto? without going through the wall of course.
Serious Roofer is offline   Reply With Quote
Old 06-07-2011, 11:40 PM   #4
Rewards Points: 5,336
You can also drill a hole and glue in a dowel. Size would depend on the fastener size used before. Let the glue dry over night and drill a pilot hole into the dowel.
Don't use old glue, it looses fastening power.
Ron
B. Franklin 1759
Old 06-07-2011, 11:50 PM   #5
Too Short? Cut it Again!
A longer lag bolt seems prudent whatever method you pick here. But...
What size lag bolt is this by the way, diameter wise? I hope it is going relatively straight into near the center of a stud and has not fractured away the edge of one? All the dowels, wood glue, and wood patch materials we can suggest will not fix the latter situation. Nor will a longer lag bolt.
Try the longer lag bolt first.
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
