Interior Half Door? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 07:55 AM   #1
Rewards Points: 77
Interior half door?
We have a wood stove in our basement. There are a couple floor registers to allow the heat to go through to the first floor. Allowed to burn long enough, it can heat half of our 2300-sq ft house. To aid with this, we keep the basement door open into the kitchen, and we put a gate at the top of the stairs to keep our son from going down (he's 15 mos old). Lately, he's realized that he can put his foot on one of the cross bars and pull himself up. We're afraid it's only a matter of time before he goes up and over (obviously we watch him all the time, but still).
I told my wife I'd look into getting a half door, which would be higher than the gate, would have no foot holes, and woudl still allow the heat from the stove to come upstairs. A google search didn't help much.
-Can you buy these things new?
-Do you need a special door frame or hinge setup?
-Can you make your own with the existing door and a really straight cut, or is it not that easy? (I'm thinking each section of door would need two hinges)
Proulx06 is offline   Reply With Quote
Old 01-22-2008, 06:38 PM   #2
Cut a solid door and install an additional hinge.
redline is offline   Reply With Quote
Old 01-22-2008, 07:00 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You have answered your own question...
- Build Well -
Old 01-22-2008, 10:49 PM   #4
Neanderthal Woodworker
woodman51jfk's Avatar
Search for "Dutch Door", that's the term for the style you are referring to.
To have a standard door cut in half, mortise for the additional hinges, install additional lockset/strike assembly, and machine & install baffles & borders.......I don't feel you'd be saving much, if any. A solid core, or slab door would be easier, but still not have the classic look, or operation of a true Dutch Door.
woodman51jfk is offline   Reply With Quote
Old 01-22-2008, 10:52 PM   #5
a link to how one person did the job, you'll have to decide if it's in your skill field:http://www.countryhome.com/projects/...tchdoor_1.html
Old 01-23-2008, 08:37 AM   #6
kimberland30's Avatar
We have an exterior dutch door. There is only one set of hardware (the bottom half). Each half has two hinges holding it to the door frame, and the upper halp "locks" into the lower half by a knob. I'll take some pictures tonight and post them. I'm sure if you could cut a solid door in half you will be able to do this on your own without too much trouble. But then again, I've never done it so what do I know?
kimberland30 is offline   Reply With Quote
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 10:00 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 05:55 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
