Interior French Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 11:00 AM   #1
We want to install French Doors in an opening that has been finished between our bedroom and sitting room. Is it possible without removing all the molding? The width is 58".X 78"
kmezza is offline   Reply With Quote
Old 03-12-2013, 11:21 AM   #2
Rewards Points: 13,300
Got a picture?
How do you plan on covering the jambs on the door if the mouldings not removed?
That's also an odd ball opening size so some reframing may need to be done.
Old 03-12-2013, 11:34 AM   #3
How old is your house, that is an odd size opening, how are you measuring it?
paintdrying is offline   Reply With Quote
Old 03-13-2013, 01:55 PM   #4
Rewards Points: 514
Two 30" doors with 1/2" rip on the four sides will make it. You need further cuts for spacing on ends and middle. 2 1/2 - 3" cuts from bottom. The cuts will make the doors look out of proportion, but not extreme.
Stops and ball latches are best to keep the doors closed.
You may have to reinforce the jambs.
carpdad is offline   Reply With Quote
Old 03-13-2013, 04:42 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
if you have to take that much material off them i would use pine doors at that. some french doors that are paint grade use filler stock which gets exposed when cuttin the door down.
woodworkbykirk is offline   Reply With Quote
Old 03-16-2013, 07:38 AM   #6
Kershaws-Doors's Avatar
You can go for French Doors without removing the molding, but the width of door sounds odd. You will have to get re-framing done to get the Fresh Doors fitted between bedroom and sitting room.
Kershaws-Doors is offline   Reply With Quote
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 03:07 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
