Interior Door Uneven At The Top (door Doesn't Latch) - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-19-2013, 09:16 PM   #16
Rewards Points: 85
I don't know if it was closing properly before. This door is in the guest bathroom so I have never noticed this issue until last week and I started doing some drywall repair before painting. No one ever (guests) mentioned anything about the door latch not working
The door is not installed in a load bearing wall.
I have checked the level of the floor and it's perfect.
Thanks again for your help.
Originally Posted by woodworkbykirk View Post
did the door work before no problem? is it installed in a bearing wall. its possible the floor has settled or even dropped do a missed point load which is putting pressure on the hinge side of the jamb
westbank is offline   Reply With Quote
Old 09-19-2013, 09:39 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
if thats the case its very possible that the door was never hung correctly in the first place.. based on the photos you providied i was looking at the mitres on hte casing to see if the mitres have opened up which is a sign of the structure moving... this being said the latch side of the header wasnt set to a even reveal along the top of the door which in turn will effect the height of the strike plate..
do as joe stated and pull the casing and reset the door
woodworkbykirk is offline   Reply With Quote
Tags
door , door frame , door jamb
Lacross Glove Box latch (sources) polarzak Automotive Repairs 2 08-07-2012 10:42 AM
Latch on Sliding Door Budfudder Windows and Doors 2 09-11-2011 04:01 AM
Door latch / seal problem trswyo Building & Construction 4 08-19-2011 08:27 AM
Maytag Quiet series 300 door latch broken Bill 1955 Appliances 2 05-31-2010 04:20 PM
Window Sash Locks Won't Latch roztom Building & Construction 2 09-05-2008 06:44 PM
