Interior Door Pinches And Is Too Wide - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 02:17 PM   #1
Question
Interior door pinches and is too wide
Hello, DIY!
I have searched the threads on sticking doors, but want to make sure I haven't missed any possible solutions.
Here's the deal: House built in 1030 with original (presumably) interior doors (5-panels and heavy as heck!)
I took the door off to paint and lost the jamb side of the hinges.
Borrowed another complete set of hinges from an unused door and it jamb.
Here's the problems: The lower part of the door strikes the stop on the hinge side. The upper part clears the stop OK.
On the striker side, the door seems to be 1/8" too wide at the striker area.
My idea is to remove the hinge-side stop and re-attach it with the door closed.
As to the 1/8" extra width, would planing the edge of the door be the correct fix?
Thanks to all in advance!
I'm newly retired and I'm a amateur repairman.
Ted
tchoate is offline   Reply With Quote
Old 04-18-2012, 06:07 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
i would shim behind the bottom hinge first as this will create a gap at the hinge between the door and jamb. then at the striker plate take off the plate itself then hold a block of wood on the jamb and hit it a couple of times with a hammer. the jamb may be loose and is coming away from the framing.. using hte block distributes the hammer blow more evenly and eliminates the chance of a hammer mark on the wood itself
woodworkbykirk is offline   Reply With Quote
Old 04-19-2012, 09:54 AM   #3
Thank you for the tips!
I'll try them and report back.
Old 04-19-2012, 10:30 AM   #4
Which side of the lower hinge would I shim? The jamb or the door?
Old 04-19-2012, 06:55 PM   #5
the jamb, keep the shim material to the front edge of the hinge so it allows the hinge to lean more which pushes the door away from teh jamb
Old 04-19-2012, 09:57 PM   #6
Kirk,
I actually fixed this door (and another one) by removing the hinge-side stop.
The door closed easily and I re-attached the stop with a slightly increased clearance from the door.
Problem solved!
Thank you for your advice and assistance!
Ted
Any way to put a 33" wide sink in a 38" wide hole? Natalie559 Plumbing 4 03-05-2012 07:02 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 03:51 PM
engineered flooring-gap along last wall too wide golfgirl Flooring 5 12-17-2010 08:14 PM
Radiant floor heat under 3x8 feet wide strip of tile - how to build up rest of floor? lazzlazz Flooring 2 03-31-2010 05:52 AM
How Should I Frame this Single 10' Wide Step? Chris' Place Remodeling 4 04-02-2008 09:31 PM
