Interior Door Issue - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 10:56 PM   #1
interior door issue
I installed a prehung interior door and for some reason the top of the door paint keeps rubbing off when its closed. Its obviously rubbing up against the door stop. I even took the door off and installed it again and its still doing it. Anyone have a clue what I can do to fix this?
mikem201 is offline   Reply With Quote
Old 02-20-2013, 11:05 PM   #2
Rewards Points: 150
Either slide top hinge 1/8 in from mortise middle hinge 1/16 in from mortise to make the top of the door not catch stops. Or move door stops in to prevent ( they are only nailed lightly to jambs)
kaschmid3 is offline   Reply With Quote
Old 02-21-2013, 09:09 AM   #3
Rewards Points: 13,270
Not sure the stop moulding can be rubbing off paint.
I can see the jamb rubbiing the door but not the stop.
The stop just keeps the door from going past the middle of the door.
How are you checking plumb and square?
And were exactly is it rubbing in relationship to the knob or hindges?
Old 02-21-2013, 04:57 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
were the stops set once the door was hung or was it just set in the hole. if they werent set thats part of the problem.. their never in the exact spot when they come from the store
woodworkbykirk is offline   Reply With Quote
Old 02-21-2013, 10:47 PM   #5
Rewards Points: 494
Maybe no primer, inferior paint and lock or strike plate is shutting the door too tight to the stop.
carpdad is offline   Reply With Quote
