-   -   interior door install ? (http://www.diychatroom.com/f14/interior-door-install-5933/)
bboy 01-15-2007 10:57 AM
I have two interior prehung doors to install. The wall is not perfectly plumb (about 1/4" out). What is the best way to install. If I want the door casing to work out I need to hold flush with wall. If I want door plumb, it will be 1/4" out at either top or bottom. I was thinking on holding top flush, then adjusting at bottom, this way casing at top will work out nice. Any suggestions?
thks!!
Brik 01-17-2007 09:23 PM
Install so the DOOR is plumb. Use a plane to shave off the jamb where its proud of the wall. Use a utility knife or rasp to shave back the drywall where its proud of the jamb. Also remember this quote from a carpenter friend "A little caulk and a little paint makes a carpenter what he ain't"!!!
