Interior Door Install - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-15-2007, 03:11 PM   #1
interior door install
this is my first whole house project, and we just got dried in. I'm planning the steps I need to accomplish before drywall, and I am not sure about the interior doors. Do they get framed in before drywall or after?
Brian
bjherron is offline   Reply With Quote
Old 09-15-2007, 03:48 PM   #2
Cabinet Installer
Dansbell's Avatar
You will typically want to wait until after you paint to install your doors.
Daniel S. Bell
Belbuilt, LLC
Cabinet Installation Medford, Oregon
http://www.belbuilt.com
Dansbell is offline   Reply With Quote
Old 09-15-2007, 05:18 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, install after....
- Build Well -
Old 09-15-2007, 07:53 PM   #4
so, just to be sure I have this correct, I would wait until after drywall/paint to install the doors and door frames?
Thanks,
Brian
Old 09-15-2007, 09:41 PM   #5
Thanks,
Brian
Install after drywall, but before the finished paint.
Doors and their corresponding trim work may also be installed after the primer is applied. (example: if the primer is sprayed onto the walls) Whatever the situation, doors should still be installed "before" the finished paint is applied.
Key point: When installing doors and their trim-work, as well as window trimwork, walls will get "dinged" or receive minor damage. Those damaged wall areas will need to be repaired with compound, and primed, before painting. That is a key reason why it is better to install doors before the finished paint work, so as to avoid having to re-paint walls multiple times.
Example:
- Build Well -
