Interior Door Casing Too Wide - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 01:53 PM   #1
Interior door casing too wide
We recently decided to upgrade the moulding in our home. Base from 3.5" to 6" & casing from 2.25" to 3.5". The problem I have is that a few of the doors were hung so close to a corner that the 3.5" casing won't fit. I could replace some of the doors with smaller ones, but for others this would be impractical. I was thinking about ripping the casing on the tight corner side, but wasn't sure how how that would look with the top piece. Any suggestions would be appreciated.
Thanks, Bob
Burlson is offline   Reply With Quote
Old 10-16-2010, 01:59 PM   #2
Rewards Points: 5,336
It generally looks like poor planning to have too many door trims truncated against a wall.
Ron
Old 10-16-2010, 02:02 PM   #3
kwikfishron's Avatar
Rewards Points: 806
It’s either rip the casing or move the door.
kwikfishron is online now   Reply With Quote
Old 10-19-2010, 04:29 PM   #4
Jay123's Avatar
I've had to do it before, not ideal but is doable. Works best when you don't have to remove too much of the side piece of trim (leg).
This has an illustration from a while back.
Framing a door that is butted up to a corner
Good luck.
Jay123 is offline   Reply With Quote
Tags
casing , moulding , ripping , trim
garage door size, is it wide enough? johnnyboy Building & Construction 5 08-24-2010 07:06 PM
6 Foot Wide Soffits Taylor B Building & Construction 2 10-28-2009 02:11 PM
How Should I Frame this Single 10' Wide Step? Chris' Place Remodeling 4 04-02-2008 09:31 PM
6" wide door jamb opening?? floxy Carpentry 3 01-15-2008 08:54 PM
bamboo flooring: wide or narrow boards? blakekr Flooring 4 11-09-2007 03:29 PM
