Insulation And Vapor Barrier In Garage - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 02:18 PM   #1
Insulation and Vapor Barrier in Garage
I have a garage that is partially finished. Meaning the common wall between house and garage is already drywalled and insulated along with ceiling (no insulation above it (crawl space/attic above garage).
So now I'm trying to finish the rest of walls by putting insulation inside the side walls...my question is...
1) Should I put a vapor barrier on side walls of garage? And what type of sealer or adhesive should I use to secure off fumes from going out of garage into house.
Common wall is finished and so is the ceiling already. Builder did that part. Now I'm finishing SIDE walls. Both are exterior walls and otherside of wall is OUTSIDE. I live in Chicago IL area just in case you need to know the climate Im living in. :-) Any help would be greatly appreciated.
Thanks Rob
DIY_Rob is offline   Reply With Quote
Old 09-01-2011, 07:46 PM   #2
Nobody? No suggestions?
