Insulation Question Please - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 02:41 PM   #1
I recently acquired a small home between Austin Tx and Dallas Tx that has the paper or vapor barrier facing up into the attic. It is stapled like crazy.
I want to add more insulation. Can I cut slits in the vapor barrier and blow in the blow in insulation or do I have to remove the old batts ? Any advice will be appreciated!
Thanks in advance
Mr-happy is offline   Reply With Quote
Old 01-24-2013, 06:31 PM   #2
Indentured Servant
Is the ceiling sheet rock? Isn't there an access panel to allow you to get up there? Trying to picture what you are saying is difficult, photos work wonderful.
jackpine is offline   Reply With Quote
Old 01-24-2013, 11:56 PM   #3
Registered User
Rewards Points: 526
Remove the vapor retarder paper facing, none is required for your location; http://www.buildingscience.com/docum...commendations/
Is the HVAC up there? http://www.buildingscience.com/docum...e-humid-south/
Just slashing the paper does nothing; "Furthermore, the amount of vapor which diffuses through a building
component is a direct function of area. That is, if 90 percent of the
building enclosure surface area is covered with a vapor retarder, then
that vapor retarder is 90 percent effective. In other words, continuity of
the vapor retarder is not as significant as the continuity of the air barrier.
For instance, polyethylene film which may have tears and numerous
punctures present will act as an effective vapor barrier, whereas at
the same time it is a poor air barrier. Similarly, the kraft-facing on fiberglass
batts installed in exterior walls acts as an effective vapor retarder,
in spite of the numerous gaps and joints in the kraft-facing." from; http://www.buildingscience.com/docum...researchreport
Gary
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Another cape insulation question exiledgator Building & Construction 21 10-14-2011 08:42 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 08:19 AM
Insulation Question skavang13 Building & Construction 3 11-16-2008 05:08 PM
