Insulate Cabin Floor - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-15-2009, 03:11 PM   #1
Question
Have a cabin that sets on crawl space. Suggestion of best way to insulate floor without have to rip it all out
dpv53 is offline   Reply With Quote
Old 11-15-2009, 03:16 PM   #2
the Musigician
DangerMouse's Avatar
use cork flooring... float over existing.
DM
Old 11-16-2009, 05:30 AM   #3
Locate floor joists in a closet , or laundry room, and cut an access in the floor, as it will be certainly used again. Get down and dirty, and use standard fiberglass batts. Even if you have to lay on your back, with your belly rubbing the bottom of the floor joists, it can be done. There is nothing pleasant about it, though.
CustomBuild is offline   Reply With Quote
Old 11-16-2009, 08:00 PM   #4
Sounds like replacing floor more fun
Old 11-16-2009, 09:16 PM   #5
Wolf
Take a look at the reply from GBR in WA to the post in the CONSTRUCTION forum titled FLOOR PLACEMENT. GBR cited http://www.buildingscience.com/docum...n-crawlspaces/ and I recommend you read it to help with your project.
ralphfravel is offline   Reply With Quote
Old 11-16-2009, 10:14 PM   #6
Registered User
Rewards Points: 526
Thank you for that, you all may use it. Isn't it something, and makes perfect sense! I found it while researching my crawlspace problem. I have a vented crawl with batts installed and v.b. over dirt already. I'm going to rip foil-faced rigid strips to install on joist bottoms with a house wrap after air sealing. The info is less than a year old.
Be safe, Gary
Old 11-18-2009, 06:13 AM   #7
Good idea
DM
Most people don't even have a clue that cork is an excellent insulator and they make some very attractive cork products today.
SULTINI is offline   Reply With Quote
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
How to insulate under a shed floor 6n165 Building & Construction 3 01-04-2008 11:55 AM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 09:53 AM
