Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-31-2011, 04:54 PM   #1
Installing a Wall Over Cinder Block Garage
Hello all.
I am interested in installing a more utilitarian wall solution in my garage, probably slat boards, over the existing cinder block.
What is the best way to secure the new wall to the cinder block?
Thanks for any advice!
Boiler98 is offline   Reply With Quote
Old 12-31-2011, 06:01 PM   #2
Tap Con screws.
Predrill the holes in the slat board before attaching or it will try and push the board away from the wall when attaching.
Old 01-01-2012, 03:41 PM   #3
In my experience cinder block walls can be very crumbly. Screws may easily strip out.
Drill a test hole and put a screw in. If it strips out, drill a hole one size smaller, and do not over torque when tightening the screws. You may also wish to use a construction adhesive like PL400, Liquid Nails or the like.
mae-ling is offline   Reply With Quote
Old 01-01-2012, 05:53 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
1x3 lath strips. fastened to wall with powder gun 1 1/4" nails use brown shots. 1x3- 16" on center
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Rebuilding a cinder block wall Pawl Building & Construction 5 10-09-2011 10:46 PM
What can you do to a Cinder Block wall? PTE8 Building & Construction 2 10-06-2011 02:06 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Cinder block wall 3DPiper Building & Construction 1 03-28-2007 12:32 PM
