Installing Vinyl Siding Around An Electrical Service On An Older House - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 03:38 PM   #1
installing vinyl siding around an electrical service on an older house
I am going to in stall Vinyl siding to my house which is clad with cedar shakes and i am leaving the shakes on and puting the vinyl over them .How do i get around the Electrical service and the mast holding the wires coming into the house with the vinyl siding? JOHN
huntercrow is offline   Reply With Quote
Old 01-28-2011, 03:50 PM   #2
Hard saying, not seeing, but if you can surround your problem area w/ 1xwhatever
, then you can run your J-channel around that.
Dwoodsmith is offline   Reply With Quote
Old 01-28-2011, 04:41 PM   #3
Thanks for your quick respose. Do you mean to put say 1x3 around the mast and service box and then put the j channel the 1x3?
Old 01-28-2011, 04:52 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Just run j channel around the box and up both sides of the mast.
Coastal South Carolina
Old 01-28-2011, 04:55 PM   #5
Thanks for your reply Is that what most siders do and does it look good when finished
Old 01-28-2011, 05:12 PM   #6
It could be as simple as the other guy said. I avoid doing vinyl siding like the plague, though I've done acres of all the other kinds. Sometimes there's a wire or a pipe going into the wall in so that it's impossible to notch the siding gracefully in a way that comes out decent. That's when I do what I said. I 'trim' around it with wood a little thicker than the siding, then butt the siding neatly to that.
The Following User Says Thank You to Dwoodsmith For This Useful Post:
huntercrow (01-28-2011)
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
How to cut vinyl siding to vent bathroom fan? db_9 General DIY Discussions 9 11-13-2009 01:58 AM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 11:35 PM
