installing vinyl siding around an electrical service on an older house
I am going to in stall Vinyl siding to my house which is clad with cedar shakes and i am leaving the shakes on and puting the vinyl over them .How do i get around the Electrical service and the mast holding the wires coming into the house with the vinyl siding? JOHN
Hard saying, not seeing, but if you can surround your problem area w/ 1xwhatever
, then you can run your J-channel around that. |
Just run j channel around the box and up both sides of the mast.
It could be as simple as the other guy said. I avoid doing vinyl siding like the plague, though I've done acres of all the other kinds. Sometimes there's a wire or a pipe going into the wall in so that it's impossible to notch the siding gracefully in a way that comes out decent. That's when I do what I said. I 'trim' around it with wood a little thicker than the siding, then butt the siding neatly to that.
| All times are GMT -4. The time now is 10:08 PM. |
