Installing A Replacement Vinyl Window With Brick Mold - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 06:30 PM   #1
Installing a Replacement Vinyl window with brick mold
Good day,
I am trying to plan the replacement of an old window in my porch. The exterior of the house is aluminum siding. The existing window is the very old wooden, single pane vertical sliding type. There is a "storm" window covering the window on the exterior - basically a second window in an aluminum frame screwed over the existing window sorta sealing it from the elements! The aluminum siding doesn't come right up to the window, as there is a bit of a frame bordering the window on which this "storm" window is screwed to. I am wondering if I simply remove the storm window and existing wooden window and just fit the new window in the opening, screw it thru the window frame and into the surrounding studs, then just calk around the brick mold of the new window and the aluminum border?
I am worried about leaking!
Thanks, and will try to get some pics if my description isn't sufficient!
- Joe
jlatulippe is offline   Reply With Quote
Old 06-22-2011, 11:20 AM   #2
Sounds good,
It is great informational post you have put up here.
Thanks for it.
____________
SEO companies
Makepeace is offline   Reply With Quote
Old 06-22-2011, 02:09 PM   #3
Replacement windows are usually made to fit in the original window frame and are screwed to this frame.
Aluminum flashing is installed around the outside perimeter and caulking is applied to seal the joints.
Old 06-23-2011, 07:47 AM   #4
Rewards Points: 5,336
Originally Posted by Makepeace View Post
Sounds good,
Thanks for it.
____________
SEO companies
That's 2 useless posts.
Ron
B. Franklin 1759
Old 06-23-2011, 03:05 PM   #5
OK! Thanks for your contribution!
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 11:06 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
