-   -   Installing a Replacement Vinyl window with brick mold (http://www.diychatroom.com/f14/installing-replacement-vinyl-window-brick-mold-108383/)
jlatulippe 06-21-2011 05:30 PM
Good day,
I am trying to plan the replacement of an old window in my porch. The exterior of the house is aluminum siding. The existing window is the very old wooden, single pane vertical sliding type. There is a "storm" window covering the window on the exterior - basically a second window in an aluminum frame screwed over the existing window sorta sealing it from the elements! The aluminum siding doesn't come right up to the window, as there is a bit of a frame bordering the window on which this "storm" window is screwed to. I am wondering if I simply remove the storm window and existing wooden window and just fit the new window in the opening, screw it thru the window frame and into the surrounding studs, then just calk around the brick mold of the new window and the aluminum border?
I am worried about leaking!
Thanks, and will try to get some pics if my description isn't sufficient!
- Joe
Makepeace 06-22-2011 10:20 AM
Sounds good,
It is great informational post you have put up here.
Thanks for it.
____________
SEO companies
Wildie 06-22-2011 01:09 PM
Replacement windows are usually made to fit in the original window frame and are screwed to this frame.
Aluminum flashing is installed around the outside perimeter and caulking is applied to seal the joints.
Ron6519 06-23-2011 06:47 AM
Originally Posted by Makepeace (Post 671973)
Sounds good,
Thanks for it.
____________
SEO companies
That's 2 useless posts.
Wildie 06-23-2011 02:05 PM
OK! Thanks for your contribution! :(
