Installing Pre Hung Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-20-2009, 08:23 AM   #1
Kellster
mjkpainting's Avatar
Rewards Points: 77
Do you guys have any tips or tricks when installing pre hung doors???? I have my rough opening and I ordered two doors.
I am finishing my basement and have doors that I am going to buy prehung. I am figuring on just using previous knowledge and common sense but I don't want to mess up too bad.
Any help you can give me would be great.
Mike
mjkpainting is offline   Reply With Quote
Old 05-20-2009, 11:31 AM   #2
Rewards Points: 5,336
Pre hung doors come with extended jamb legs so the door will clear rugs or a saddle. You need to decide how much clearance you need for your application and cut the legs to the proper length or leave them alone. If the floor isn't level you will need to cut the legs so that the top reveal is equal accross the door. The cuts could be different. If a rug is going down, you can just shim one side as the rug will cover the shim.
After this is done you can put the door into the opening and start the install. You'll secure the hinge side first. Add shims as needed and tack the jamb in place. Shims go behind each hinge. The door should be 1/8" away from the jamb from top to bottom if you did it correctly.
The latch side will be the same. Set the shims so the reveal is 1/8" and nail it in place. Close the door and make sure the door hits the door stops at the same time. If it hits the bottom before the top, you need to make an adjustment.
This will go more easily if the framing is plumb and square.
Ron
Old 05-20-2009, 11:40 AM   #3
Common sense will suffice.
Take it apart, hang the half that has the door on it first, you can take the door off by pulling the hinge pins off but that isn't necessary.
If your floor is finished just set it on the floor. If you are going to add tile/wood/carpet later, do that now and hang the doors afterward, or consider the height of the finished floor.
Be sure the casing on the opposite (strike) side reaches over the drywall at the top. If its short slide the whole thing over.
You can hang it by plumbing the casing on the hinge side and nailing the casing into the wall.
Then close the door, level the top casing, and check the reveal across the top of the door.
Nail the top casing where it is level and the reveal is even.
Then plumb the strike side casing and check that reveal too.
Before attaching the other set of casing, shim in 2 - 3 places between the hinge jamb and the stud behind it and nail that jamb through the shims. This is so the whole door isn't hanging on those little brad they have nailing the casing to the jamb.
Then slide the other casing into the set you have attached, check that it operates, is securely attached and looks good, and nail the other set of casing around its perimeter.
VaViaCo is offline   Reply With Quote
Old 05-20-2009, 09:02 PM   #4
Old School
Willie T's Avatar
I tried to load this, but the forum would not accept its length.
Here is my door hanging document.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
crankcase (03-12-2013)
Old 05-20-2009, 09:09 PM   #5
Rewards Points: 85
MJ
Used to be a picture was worth a 1000 words now its a video thanks to the WWW. Try this site:
http://hwtv.jlconline.com/default.as...tid=1326159170
Best of luck with the project, rredogg
rredogg is offline   Reply With Quote
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 12:23 PM
Installing a new exterior door. TobyLLM Carpentry 2 04-09-2008 04:51 PM
Pre Hung Door Issue! bmster Carpentry 8 03-11-2008 08:31 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
