Installing New Treads To Morticed Stringer - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 08:55 PM   #1
Installing new treads to morticed stringer
I am looking to install new oak treads in place of the existing pine ones previously carpeted over. Reading enough material to appreciate that the stair risers should be the same height, I've pursuaded myself against installing retro fit treads that would leave the first and last riser 1" off height from the rest of the stairs. The problem I've found myself in is that the treads are morticed in. For some reason the stringer at the bottoms stair was cut so that the tread could be slid out from the front (after cutting the nails keeping it in place).
I really really don't want to tear down the drywall on the rear of the stairs. If possible, I would prefer to extend the mortice to the front of the stair, slide the old ones out, the new ones in and patch the mortices.
Is this a legitimate option? Is there an easier way I'm not thinking of without accessing the rear of the stairs?
pm634 is offline   Reply With Quote
Old 07-09-2012, 08:57 AM   #2
Too Short? Cut it Again!
There is a potential safety issue if you provide a continuous groove. And won't you spend as much time cutting the grooves all the way as replacing a sheet of drywall or two? And how would you hold the treads in place in a continuous groove? Finally, won't it look goofy?
Old 07-09-2012, 07:51 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
Mortised or "housed" stringers are, in my opinion the best way to fabricate a stair. They are a structural element to the stair which provides ease of tread installation and the cleanest and most professional look. Doing as you describe will compromise all of this. Drywall is easy to replace. I would rip it down and cut out all the treads and risers and clean out the wedges that are left behind. Take my word for it, if you want it done right that is what you should do.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
user1007 (07-09-2012)
Old 07-10-2012, 09:24 AM   #4
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
You could consider this, if you are willing to use a veneered tread.
Cutting the pieces is a little tricky if you are not skilled at it, but I can guide you through if you PM me.
You can also pre-finish all the pieces after you fit them, then glue them into place and use a pin gun for the 1/4 round.
The veneered plywood of 1/4" thick will not impact the height difference by much.
The drawing is what we call a "Fag packet sketch" as I spent all of 2 minutes on it
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 02:21 PM
Installing new stair treads Hank98 Carpentry 12 01-06-2012 06:47 PM
Repair Stair Stringer sunshine54 Flooring 2 11-27-2011 11:06 PM
Installing skirtboards grod777 Carpentry 18 10-03-2011 09:25 AM
Pennsylvania Bluestone Treads rjordan392 Building & Construction 4 03-30-2008 10:37 PM
