installing new french patio doors
Check This book out from the library.
http://www.amazon.com/Complete-Doors...0590669&sr=8-1
It has a section on adding doors where no doors were previously. I'm willing to bet your current header is either not as wide as your french doors or your current header is too low. Either way this book will help. It will show you how to remove the window. When the window is gone you treat the wall as if it were a full wall and follow the directions on installing a new door. Seriously...this book is what you need. It will walk you through it step by step.
If not take a picture or two, get the window height from the floor and width measurements and I'll try to walk you through what i would do.
I WILL PERSIST UNTIL I SUCCEED. I AM A LION AND I REFUSE TO TALK, TO WALK, TO SLEEP WITH THE SHEEP. THE SLAUGHTERHOUSE OF FAILURE IS NOT MY DESTINY. I WILL PERSIST UNTIL I SUCCEED.
