Installing New Exterior Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 12:04 AM   #1
installing new exterior wall
I'm adding on to my house I i need to frame up the wall to weather proof it but I dont have the windows can I still put the wall up and install the window later?
talon77 is offline   Reply With Quote
Old 04-21-2011, 12:10 AM   #2
Rewards Points: 87
It'll be much easier for you to put a window at framing stage then add on later ... but you can do that if you choose to...
A picture is worth a thousand words.
Stephen S. is offline   Reply With Quote
Old 04-21-2011, 07:03 AM   #3
DIY staff
Rewards Points: 7,174
As long as they are installed before the siding goes on you are O.K.
Cover the openings with Tyvec and get to building.
Old 04-21-2011, 08:42 AM   #4
Rewards Points: 5,336
Just frame the rough opening and don't cut out the opening in the plywood until the windows get there,
Ron
Installing bathtub Tudy Kitchen & Bath Remodeling 11 10-19-2010 07:55 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 10:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 12:11 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 08:38 AM
