Installing Interior Tongue And Groove Wood Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 09:10 PM   #1
installing interior tongue and groove wood siding
I've got 1 by 6 inch yellow pine #2 tongue and groove siding installing horizontally. I plan on using an finish nail gun. What size nails and gun should I buy? I know to start at the bottom tongue side up and blind nail the tongue. Any other advice is appreciated. Thanks.
freemike11 is offline   Reply With Quote
Old 05-10-2011, 10:00 PM   #2
You can use anything from an 18 ga to a 15 ga. I would suggest something in the middle a 16 ga. And make sure whatever length of nail you use is is long enough to go through the material, dry wall, and at least 3/4" into the studs. So probably 2" nails.
sausagefingers is offline   Reply With Quote
Wood floor on a tongue & groove subfloor. Huckleberry Flooring 4 05-10-2011 09:41 PM
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 08:58 AM
Should tongue and groove siding be caulked? apara Building & Construction 5 08-15-2010 07:07 PM
Installing fiber cement siding over existing siding elsobrider Carpentry 20 08-04-2010 06:34 PM
How to repair vertical wood siding? darsunt Building & Construction 1 11-19-2009 07:46 PM
