Installing Interior Doors - Slab - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-16-2008, 05:45 PM   #16
BUILDER / REMODELING CONT
buletbob's Avatar
That would be the best thing to do, BOB
Old 10-17-2008, 08:45 PM   #17
Originally Posted by Chagres View Post
OK, this might sound simplistic, but do you still have the old door? Did it close properly? I know you said some of them didn't. If this old one didn't have the same problem, just compare the old one with the new one - it might give you a clue to the best solution. Hope this helps.
Chagres (Kelly)
http://www.icanfixupmyhome.com
Unfortunately, this is one of the doors that didn't close properly before, otherwise we would have tried to use the old door as a template. We do plan on doing this with some of the doors that work properly.
jkrodger is offline   Reply With Quote
Old 10-17-2008, 08:50 PM   #18
Originally Posted by S&S Custom Trim &Paint View Post
If it is still catching on the frame,then the bottom mortise is still to deep and needs to be out further.Un less it is hitting the stop.These old houses are hard if you have not done a bunch. I did this before also.I had to re-drill my holes for the hinge forward a bit(on the door)so that it pulled away from the stop.I hope you understand what I mean.I am trying,it's hard to put into words.
Sorry, I'm new to the door DIY, what exactly is the stop? I think I understand what your talking about with moving the bottom hinge, so I'd carve out more of a hinge mortise (not deeper, bigger space so the hinge will fit more in the door width-wise), right?
About the cardboard shims, since the door will need to be taken down again, I plan on just using some wood filled and adding a layer(s) so we get the distance back but don't need the shims.
Old 10-18-2008, 05:29 AM   #19
buletbob's Avatar
PIC'S
Old 10-18-2008, 10:32 AM   #20
Drywall contractor
Rewards Points: 1,070
The stop is the part of the jamb the door closes (or "stops") against.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-19-2008, 06:57 PM   #21
ok ok, weekend guests finally left, here are some pictures:
Here's the full door, as far as it will close on it's own:
Here's a shot of where the door is catching:
middle
bottom
more coming...
Old 10-19-2008, 07:00 PM   #22
bottom hinge:
other side of bottom hinge (ignore the paint we got on it, and yes, we will be removing the cardboard shims and using wood filler to bring the hinges flush with the door, but not until we figure out how to make it close all the way)
Yes, we know painting it was useless because we'll have to repaint after we're done with this fix anyways, but we were tired of looking at the primed doors and had guests coming, so we went ahead and threw the first coat on the door.
Old 10-19-2008, 07:22 PM   #23
buletbob's Avatar
your first picture of the door seems as if the top and bottom hinges are mortised differently, the door looks as if it is hitting the jamb. and the space between the door and the stop ,I try to maintain a thickness of a charge card. this will allow for paint and swelling. and as with the last picture it appears as the hinge is sticking out to much from the edge of the door. Close the door and put a straight edge against all three hinges to see if all three are touching the straight edge which is what you want.
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
