Installing An Interior Door: Retro Fit Or Start Over? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-17-2014, 08:49 PM   #1
hohadcr's Avatar
Rewards Points: 346
installing an interior door: retro fit or start over?
i need to add an interior door to a "room" that has only a finished frame.
optionA.
just buy a door, cut hinge slots some how in the existing frame, add stoppers, drill lock holes ect on the existing frame.
problem: hing side of the existing door frame is not plumb, about 3/4 inch off on the top. this means that i will have to somehow hack a plumb frame for the new door. also i need to put an extra wide molding in the hing side to hide my hack job, and then finish w/ painting .
option B:
take down existing moldings and frame, install a pre hung door, and finish w/ moldings and painting
everything considered, which option is bettter?
i kinda know the answer now...
hohadcr is offline   Reply With Quote
Old 07-18-2014, 05:26 AM   #2
DIY staff
Rewards Points: 7,174
Prehung doors are faster and cheaper in the long run---in your case,with an out of plumb jamb---an easy decision---
Old 07-18-2014, 10:48 AM   #3
hohadcr's Avatar
Rewards Points: 346
Yeah, I thought so too!!
Thanks, Mike!
Old 07-18-2014, 12:18 PM   #4
Rewards Points: 144
+1 If that is you picture and you were not in Canada,I would just come over and do it for you.Sorry my Visa is expired.
mako1 is offline   Reply With Quote
Old 07-18-2014, 02:35 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
if the existing frame is fairly plumb and square i will just retrofit it.. but in your instance where its so bad just tear it out and start fresh
woodworkbykirk is offline   Reply With Quote
Old 07-18-2014, 02:38 PM   #6
Rewards Points: 144
Sorry for the earlier comment.Could not help it.It would be easier and cheaper to buy a new prehung door as others have said.
I will add to check the thickness of your wall before buying.If it is different than standard you may want to buy a split jamb door.
Old 07-19-2014, 07:48 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
if you get a new prehung for it then plan to get larger door casing so you do not have to paint the walls unless you plan to paint the walls anyway. as a side note- you can cut a door to fit an out of square opening and it will swing fine, just make the door sit level and plumb and take the difference in the out of square jamb out of the door, like 3/4" to nothing for the rip.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
woodworkbykirk (07-19-2014)
Mower won't start dmlove67 Landscaping & Lawn Care 6 03-20-2013 05:15 AM
Where to start laying Allure Ultra Saltyeskimo Flooring 0 09-28-2012 06:50 PM
Installing 1000 sq. ft. of Engineered Hardwood...How to start it. simmons2k Flooring 6 01-30-2012 09:46 AM
Where to start - Hardwood floor installation JulianaCR Flooring 24 03-14-2011 04:33 PM
new pergo - where to start laying first course snowninja Flooring 4 09-25-2010 04:47 PM
